Ana içeriğe geç
Asus GL551JW-AH71 Display Assembly Replacement
Neye ihtiyacın var
  1. Asus GL551JW-AH71 Display Assembly Replacement, Battery: adım 1, 1 resimden 1.
    • Close the device and lay it upside down.
    • Unplug the device and make sure the device is powered off before removing the battery.
    FixBot'a Sor
    Yorum Ekle
  2. Asus GL551JW-AH71 Display Assembly Replacement: adım 2, 2 resimden 1. Asus GL551JW-AH71 Display Assembly Replacement: adım 2, 2 resimden 2.
    • Move the battery eject button to the right. The battery will be ejected.
    FixBot'a Sor
    Yorum Ekle
  3. Asus GL551JW-AH71 Display Assembly Replacement: adım 3, 2 resimden 1. Asus GL551JW-AH71 Display Assembly Replacement: adım 3, 2 resimden 2.
    • Grab the battery and remove it from the device.
    FixBot'a Sor
    Yorum Ekle
  4. Asus GL551JW-AH71 Display Assembly Replacement, Optical Drive: adım 4, 2 resimden 1. Asus GL551JW-AH71 Display Assembly Replacement, Optical Drive: adım 4, 2 resimden 2.
    • Use a Phillips #000 screwdriver to remove the single 10mm optical drive screw.
    FixBot'a Sor
    Yorum Ekle
  5. Asus GL551JW-AH71 Display Assembly Replacement: adım 5, 3 resimden 1. Asus GL551JW-AH71 Display Assembly Replacement: adım 5, 3 resimden 2. Asus GL551JW-AH71 Display Assembly Replacement: adım 5, 3 resimden 3.
    • Insert a probe or paperclip gently into the eject pin hole to eject the optical drive tray.
    FixBot'a Sor
    Yorum Ekle
  6. Asus GL551JW-AH71 Display Assembly Replacement: adım 6, 2 resimden 1. Asus GL551JW-AH71 Display Assembly Replacement: adım 6, 2 resimden 2.
    • Gently grasp the optical drive assembly and slide it out of the laptop body.
    FixBot'a Sor
    Yorum Ekle
  7. Asus GL551JW-AH71 Display Assembly Replacement, Upper Assembly: adım 7, 2 resimden 1. Asus GL551JW-AH71 Display Assembly Replacement, Upper Assembly: adım 7, 2 resimden 2.
    • Using a Phillips #000 screwdriver, remove the two 11mm screws that hold the access panel in place.
    FixBot'a Sor
    Yorum Ekle
  8. Asus GL551JW-AH71 Display Assembly Replacement: adım 8, 2 resimden 1. Asus GL551JW-AH71 Display Assembly Replacement: adım 8, 2 resimden 2.
    • Carefully remove the access panel.
    FixBot'a Sor
    Yorum Ekle
  9. Asus GL551JW-AH71 Display Assembly Replacement: adım 9, 2 resimden 1. Asus GL551JW-AH71 Display Assembly Replacement: adım 9, 2 resimden 2.
    • Using a Phillips #000 screwdriver, remove the seven 11mm screws holding lower case to the laptop.
    FixBot'a Sor
    Yorum Ekle
  10. Asus GL551JW-AH71 Display Assembly Replacement: adım 10, 1 resimden 1.
    • Turn the laptop over and open the screen.
    FixBot'a Sor
    Yorum Ekle
  11. Asus GL551JW-AH71 Display Assembly Replacement: adım 11, 3 resimden 1. Asus GL551JW-AH71 Display Assembly Replacement: adım 11, 3 resimden 2. Asus GL551JW-AH71 Display Assembly Replacement: adım 11, 3 resimden 3.
    • Gently pry open the case with an iFixit opening tool.
    • The upper and lower assembly are connected with a display cable that will be removed in the next step. Do not pull the parts apart more than a few inches.
    FixBot'a Sor
    Yorum Ekle
  12. Asus GL551JW-AH71 Display Assembly Replacement: adım 12, 3 resimden 1. Asus GL551JW-AH71 Display Assembly Replacement: adım 12, 3 resimden 2. Asus GL551JW-AH71 Display Assembly Replacement: adım 12, 3 resimden 3.
    • Flip the laptop on the right side while still holding the upper and lower assemblies close together.
    • Unplug the display connector from the motherboard.
    • Remove the upper assembly.
    FixBot'a Sor
    Yorum Ekle
  13. Asus GL551JW-AH71 Display Assembly Replacement, Display Assembly: adım 13, 2 resimden 1. Asus GL551JW-AH71 Display Assembly Replacement, Display Assembly: adım 13, 2 resimden 2.
    • Remove the three 5mm screws located in each circle with a Phillips #000 screwdriver.
    • A total of twelve 5mm screw should be removed in order to free the display assembly from the base.
    FixBot'a Sor
    Yorum Ekle
  14. Asus GL551JW-AH71 Display Assembly Replacement: adım 14, 2 resimden 1. Asus GL551JW-AH71 Display Assembly Replacement: adım 14, 2 resimden 2.
    • Lift the display assembly up, separating it from the base of the device.
    FixBot'a Sor
    Yorum Ekle
  15. Asus GL551JW-AH71 Display Assembly Replacement: adım 15, 3 resimden 1. Asus GL551JW-AH71 Display Assembly Replacement: adım 15, 3 resimden 2. Asus GL551JW-AH71 Display Assembly Replacement: adım 15, 3 resimden 3.
    • Using a plastic opening tool, separate the bezel from the screen.
    • Insert the tool and slide it right to left to release the bezel from the screen.
    FixBot'a Sor
    Yorum Ekle
  16. Asus GL551JW-AH71 Display Assembly Replacement: adım 16, 2 resimden 1. Asus GL551JW-AH71 Display Assembly Replacement: adım 16, 2 resimden 2.
    • Remove the four screws using a Phillips #0 screwdriver.
    FixBot'a Sor
    Yorum Ekle
  17. Asus GL551JW-AH71 Display Assembly Replacement: adım 17, 2 resimden 1. Asus GL551JW-AH71 Display Assembly Replacement: adım 17, 2 resimden 2.
    • Grab the screen in the corners and lift up to remove it.
    FixBot'a Sor
    Yorum Ekle
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Alec Pimentel
258 İtibar
1 Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S8-G3, Bailey Spring 2019 UMass Dartmouth, Team S8-G3, Bailey Spring 2019 üyesi
UMASSD-BAILEY-S19S8G3
4 Üyeler
16 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 19
Her zaman: 1,147
