Ana içeriğe geç
Asus GL551JW-AH71 Fan Replacement
Neye ihtiyacın var
  1. Asus GL551JW-AH71 Fan Replacement, Battery: adım 1, 1 resimden 1.
    • Close the device and lay it upside down.
    • Unplug the device and make sure the device is powered off before removing the battery.
  2. Asus GL551JW-AH71 Fan Replacement: adım 2, 2 resimden 1. Asus GL551JW-AH71 Fan Replacement: adım 2, 2 resimden 2.
    • Move the battery eject button to the right. The battery will be ejected.
  3. Asus GL551JW-AH71 Fan Replacement: adım 3, 2 resimden 1. Asus GL551JW-AH71 Fan Replacement: adım 3, 2 resimden 2.
    • Grab the battery and remove it from the device.
  4. Asus GL551JW-AH71 Fan Replacement, Optical Drive: adım 4, 2 resimden 1. Asus GL551JW-AH71 Fan Replacement, Optical Drive: adım 4, 2 resimden 2.
    • Use a Phillips #000 screwdriver to remove the single 10mm optical drive screw.
  5. Asus GL551JW-AH71 Fan Replacement: adım 5, 3 resimden 1. Asus GL551JW-AH71 Fan Replacement: adım 5, 3 resimden 2. Asus GL551JW-AH71 Fan Replacement: adım 5, 3 resimden 3.
    • Insert a probe or paperclip gently into the eject pin hole to eject the optical drive tray.
  6. Asus GL551JW-AH71 Fan Replacement: adım 6, 2 resimden 1. Asus GL551JW-AH71 Fan Replacement: adım 6, 2 resimden 2.
    • Gently grasp the optical drive assembly and slide it out of the laptop body.
  7. Asus GL551JW-AH71 Fan Replacement, Upper Assembly: adım 7, 2 resimden 1. Asus GL551JW-AH71 Fan Replacement, Upper Assembly: adım 7, 2 resimden 2.
    • Using a Phillips #000 screwdriver, remove the two 11mm screws that hold the access panel in place.
  8. Asus GL551JW-AH71 Fan Replacement: adım 8, 2 resimden 1. Asus GL551JW-AH71 Fan Replacement: adım 8, 2 resimden 2.
    • Carefully remove the access panel.
  9. Asus GL551JW-AH71 Fan Replacement: adım 9, 2 resimden 1. Asus GL551JW-AH71 Fan Replacement: adım 9, 2 resimden 2.
    • Using a Phillips #000 screwdriver, remove the seven 11mm screws holding lower case to the laptop.
  10. Asus GL551JW-AH71 Fan Replacement: adım 10, 1 resimden 1.
    • Turn the laptop over and open the screen.
  11. Asus GL551JW-AH71 Fan Replacement: adım 11, 3 resimden 1. Asus GL551JW-AH71 Fan Replacement: adım 11, 3 resimden 2. Asus GL551JW-AH71 Fan Replacement: adım 11, 3 resimden 3.
    • Gently pry open the case with an iFixit opening tool.
    • The upper and lower assembly are connected with a display cable that will be removed in the next step. Do not pull the parts apart more than a few inches.
  12. Asus GL551JW-AH71 Fan Replacement: adım 12, 3 resimden 1. Asus GL551JW-AH71 Fan Replacement: adım 12, 3 resimden 2. Asus GL551JW-AH71 Fan Replacement: adım 12, 3 resimden 3.
    • Flip the laptop on the right side while still holding the upper and lower assemblies close together.
    • Unplug the display connector from the motherboard.
    • Remove the upper assembly.
  13. Asus GL551JW-AH71 Fan Replacement, Fan: adım 13, 1 resimden 1.
    • Place the separated motherboard keyboard side down.
  14. Asus GL551JW-AH71 Fan Replacement: adım 14, 3 resimden 1. Asus GL551JW-AH71 Fan Replacement: adım 14, 3 resimden 2. Asus GL551JW-AH71 Fan Replacement: adım 14, 3 resimden 3.
    • Unplug the fan connector cable from the motherboard with an iFixit opening tool.
  15. Asus GL551JW-AH71 Fan Replacement: adım 15, 2 resimden 1. Asus GL551JW-AH71 Fan Replacement: adım 15, 2 resimden 2.
    • With a Phillips #00 screwdriver, remove the three 5mm screws that hold the fan in place.
  16. Asus GL551JW-AH71 Fan Replacement: adım 16, 2 resimden 1. Asus GL551JW-AH71 Fan Replacement: adım 16, 2 resimden 2.
    • Gently remove the fan from the motherboard.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
William Kelley
1.035 İtibar
7 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S8-G3, Bailey Spring 2019 UMass Dartmouth, Team S8-G3, Bailey Spring 2019 üyesi
UMASSD-BAILEY-S19S8G3
4 Üyeler
16 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 6
Son 30 gün: 13
Her zaman: 1,583
