Ana içeriğe geç
Asus GL551JW-AH71 Optical Drive Replacement
Neye ihtiyacın var
  1. Asus GL551JW-AH71 Optical Drive Replacement, Battery: adım 1, 1 resimden 1.
    • Close the device and lay it upside down.
    • Unplug the device and make sure the device is powered off before removing the battery.
  2. Asus GL551JW-AH71 Optical Drive Replacement: adım 2, 2 resimden 1. Asus GL551JW-AH71 Optical Drive Replacement: adım 2, 2 resimden 2.
    • Move the battery eject button to the right. The battery will be ejected.
  3. Asus GL551JW-AH71 Optical Drive Replacement: adım 3, 2 resimden 1. Asus GL551JW-AH71 Optical Drive Replacement: adım 3, 2 resimden 2.
    • Grab the battery and remove it from the device.
  4. Asus GL551JW-AH71 Optical Drive Replacement, Optical Drive: adım 4, 2 resimden 1. Asus GL551JW-AH71 Optical Drive Replacement, Optical Drive: adım 4, 2 resimden 2.
    • Use a Phillips #000 screwdriver to remove the single 10mm optical drive screw.
  5. Asus GL551JW-AH71 Optical Drive Replacement: adım 5, 3 resimden 1. Asus GL551JW-AH71 Optical Drive Replacement: adım 5, 3 resimden 2. Asus GL551JW-AH71 Optical Drive Replacement: adım 5, 3 resimden 3.
    • Insert a probe or paperclip gently into the eject pin hole to eject the optical drive tray.
  6. Asus GL551JW-AH71 Optical Drive Replacement: adım 6, 2 resimden 1. Asus GL551JW-AH71 Optical Drive Replacement: adım 6, 2 resimden 2.
    • Gently grasp the optical drive assembly and slide it out of the laptop body.
Sonuç
Bir başkası bu kılavuzu tamamladı.
William Kelley
1.035 İtibar
7 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S8-G3, Bailey Spring 2019 UMass Dartmouth, Team S8-G3, Bailey Spring 2019 üyesi
UMASSD-BAILEY-S19S8G3
4 Üyeler
16 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 8
Her zaman: 379
