Ana içeriğe geç
Asus GTX 750 GPU Fan Replacement
Neye ihtiyacın var
  1. Asus GTX 750 GPU Fan Replacement, Asus GTX 750 GPU Fan: adım 1, 3 resimden 1. Asus GTX 750 GPU Fan Replacement, Asus GTX 750 GPU Fan: adım 1, 3 resimden 2. Asus GTX 750 GPU Fan Replacement, Asus GTX 750 GPU Fan: adım 1, 3 resimden 3.
    • Before beginning the repair process, make sure that your designated workspace is decluttered and clean.
    • The smaller parts of the device may be at risk of being lost or misplaced if the workspace is not decluttered.
    • Orient the case so that the power button is aligned with the rightmost corner of the device.
    • Next, push the ridge-line of the top panel away.
    • Then, slide the case away and expose the inside of the product.
    • Continue this process to lift off the side panel that was previously facing you.
  2. Asus GTX 750 GPU Fan Replacement: adım 2, 2 resimden 1. Asus GTX 750 GPU Fan Replacement: adım 2, 2 resimden 2.
    • Next, disconnect the GPU cable with your thumb and forefinger. This will partially unhook the fan from the motherboard.
    • If working with any model of this device other than the ASUS GTX 750, pull the cable away from the motherboard. If not, this note may be disregarded.
    • On the PCIe slot of the graphics card, there is a release mechanism. Push on this mechanism carefully and gently.
    • After pushing it down, the device will click and signify correct and complete separation from the motherboard.
    • Use caution, and do not touch the motherboard with your bare hands, as it may cause a short in the system.
  3. Asus GTX 750 GPU Fan Replacement: adım 3, 2 resimden 1. Asus GTX 750 GPU Fan Replacement: adım 3, 2 resimden 2.
    • Finally, with the GPU unit exposed, disconnect the 4-pin fan power and speed control cable from the circuit board.
    • Refer to the photographs on the left if needed.
  4. Asus GTX 750 GPU Fan Replacement: adım 4, 1 resimden 1.
    Bu adımda kullanılan alet:
    Phillips #00 Screwdriver
    $5.49
    Satın Al
    • Remove the four smallest screws that are holding the fan shroud in place.
    • Do so by using a (Phillips #00) screwdriver between the fan blades and corresponding supporting bracket.
  5. Asus GTX 750 GPU Fan Replacement: adım 5, 2 resimden 1. Asus GTX 750 GPU Fan Replacement: adım 5, 2 resimden 2.
    • Locate the two clips on either side of the fan shroud.
    • Then, pull the clips slightly to the side and release the fan shroud from the heatsink.
    • Finally, pull the fan shroud vertically to remove from the device and allow for an unobstructed review and repair.
  6. Asus GTX 750 GPU Fan Replacement: adım 6, 1 resimden 1.
    • At this stage, you may reverse the disassembly process to reassemble the fan shroud and place it within the unit.
Sonuç
In order to reassemble this device, follow the provided instructions in the reverse order.
2 farklı kişi bu kılavuzu tamamladı.
Zhiming Lin
178 İtibar
1 Kılavuz yazıldı
Ekip
York University, Team A-4, Morris Fall 2022 York University, Team A-4, Morris Fall 2022 üyesi
YORK-MORRIS-F22SAG4
4 Üyeler
2 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 25
Her zaman: 1,276
