Ana içeriğe geç
Asus K50IJ Fan Replacement
Neye ihtiyacın var
  1. Asus K50IJ Fan Replacement, Battery: adım 1, 1 resimden 1.
    • Slide the tab over to unlock the battery cover located on the bottom-left corner of the laptop.
    FixBot'a Sor
    Yorum Ekle
  2. Asus K50IJ Fan Replacement: adım 2, 3 resimden 1. Asus K50IJ Fan Replacement: adım 2, 3 resimden 2. Asus K50IJ Fan Replacement: adım 2, 3 resimden 3.
    • Lift the exposed lip and remove the battery cover.
    FixBot'a Sor
    Yorum Ekle
  3. Asus K50IJ Fan Replacement: adım 3, 3 resimden 1. Asus K50IJ Fan Replacement: adım 3, 3 resimden 2. Asus K50IJ Fan Replacement: adım 3, 3 resimden 3.
    • Press the tabs on the battery and lift them. The battery should come out easily.
    FixBot'a Sor
    Yorum Ekle
  4. Asus K50IJ Fan Replacement, Fan: adım 4, 3 resimden 1. Asus K50IJ Fan Replacement, Fan: adım 4, 3 resimden 2. Asus K50IJ Fan Replacement, Fan: adım 4, 3 resimden 3.
    • Using the PH1 screwdriver, remove the four 4 .75 mm screws that are located on the vent panel.
    FixBot'a Sor
    Yorum Ekle
  5. Asus K50IJ Fan Replacement: adım 5, 1 resimden 1.
    • Remove the one .5 mm screw located in the top right corner of the battery compartment.
    FixBot'a Sor
    Yorum Ekle
  6. Asus K50IJ Fan Replacement: adım 6, 2 resimden 1. Asus K50IJ Fan Replacement: adım 6, 2 resimden 2.
    • Remove the bottom panel by sliding it toward the hinges and lifting the back panel up.
    FixBot'a Sor
    Yorum Ekle
  7. Asus K50IJ Fan Replacement: adım 7, 1 resimden 1.
    • Unplug the wire cable attached to the fan by pulling it out .
    FixBot'a Sor
    Yorum Ekle
  8. Asus K50IJ Fan Replacement: adım 8, 2 resimden 1. Asus K50IJ Fan Replacement: adım 8, 2 resimden 2.
    • Using the PH1 screwdriver, remove the 3 .75mm screws labeled as 1, 2, and 3 on the fan. NOTE these screws have the labels "1", "2", and "3" next to them.
    • Lift the fan up with your fingers.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 6
Son 30 gün: 24
Her zaman: 1,192
