Ana içeriğe geç
Asus K53E-BBR3 Hard Drive Replacement
Neye ihtiyacın var
  1. Asus K53E-BBR3 Hard Drive Replacement, Battery: adım 1, 3 resimden 1. Asus K53E-BBR3 Hard Drive Replacement, Battery: adım 1, 3 resimden 2. Asus K53E-BBR3 Hard Drive Replacement, Battery: adım 1, 3 resimden 3.
    • Place your laptop face down in front of you.
    • Slide the button in the top right corner to the right so that the orange marker is showing.
    • Press the spring loaded latch to release the battery from the computer.
  2. Asus K53E-BBR3 Hard Drive Replacement, Back Panel: adım 2, 1 resimden 1.
    • Unscrew two 5mm Phillips #1 screws.
  3. Asus K53E-BBR3 Hard Drive Replacement: adım 3, 1 resimden 1.
    • Pull down and lift up on the back panel to remove it.
  4. Asus K53E-BBR3 Hard Drive Replacement, Hard Drive: adım 4, 3 resimden 1. Asus K53E-BBR3 Hard Drive Replacement, Hard Drive: adım 4, 3 resimden 2. Asus K53E-BBR3 Hard Drive Replacement, Hard Drive: adım 4, 3 resimden 3.
    • Unscrew the four 5mm Phillips #1 screws.
    • Lift the hard drive out of the computer.
  5. Asus K53E-BBR3 Hard Drive Replacement: adım 5, 2 resimden 1. Asus K53E-BBR3 Hard Drive Replacement: adım 5, 2 resimden 2.
    • Unscrew the screws on the hard drive case.
    • Two 3mm Phillips #1 screws are located on one edge of the case.
    • The last two 3mm #1 Phillips screws are located on the opposite side of the case.
    • After you unscrew all four screws, the metal cage will fall off, leaving you with the hard drive.
Sonuç
Jacob O'Donnell
323 İtibar
3 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 1-1, Catania Fall 2016 UMass Dartmouth, Team 1-1, Catania Fall 2016 üyesi
UMASSD-CATANIA-F16S1G1
3 Üyeler
7 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 6
Son 30 gün: 15
Her zaman: 1,751
