Ana içeriğe geç
Asus K53E-BBR3 Keyboard Replacement
Neye ihtiyacın var
    1. Asus K53E-BBR3 Keyboard Replacement, Battery: adım 1, 3 resimden 1. Asus K53E-BBR3 Keyboard Replacement, Battery: adım 1, 3 resimden 2. Asus K53E-BBR3 Keyboard Replacement, Battery: adım 1, 3 resimden 3.
      • Place your laptop face down in front of you.
      • Slide the button in the top right corner to the right so that the orange marker is showing.
      • Press the spring loaded latch to release the battery from the computer.
      FixBot'a Sor
      Yorum Ekle
    1. Asus K53E-BBR3 Keyboard Replacement, Keyboard: adım 2, 3 resimden 1. Asus K53E-BBR3 Keyboard Replacement, Keyboard: adım 2, 3 resimden 2. Asus K53E-BBR3 Keyboard Replacement, Keyboard: adım 2, 3 resimden 3.
      • There is a ribbon connector underneath the keyboard. When lifting up the keyboard be gentle and carefully it up.
      • Insert the spudger into the indent near the "ESC" key.
      • Firmly wiggle the spudger across the keyboard in between the space until you can remove the keyboard.
      FixBot'a Sor
      Yorum Ekle
    2. Asus K53E-BBR3 Keyboard Replacement: adım 3, 1 resimden 1.
      • Gently pull the ribbon cable to the right and out of its port.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Liza Sousa
355 İtibar
3 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 1-1, Catania Fall 2016 UMass Dartmouth, Team 1-1, Catania Fall 2016 üyesi
UMASSD-CATANIA-F16S1G1
3 Üyeler
69 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 34
Her zaman: 1,100
