Ana içeriğe geç
Asus K53E-BBR3 RAM Replacement
Neye ihtiyacın var
  1. Asus K53E-BBR3 RAM Replacement, Battery: adım 1, 3 resimden 1. Asus K53E-BBR3 RAM Replacement, Battery: adım 1, 3 resimden 2. Asus K53E-BBR3 RAM Replacement, Battery: adım 1, 3 resimden 3.
    • Place your laptop face down in front of you.
    • Slide the button in the top right corner to the right so that the orange marker is showing.
    • Press the spring loaded latch to release the battery from the computer.
  2. Asus K53E-BBR3 RAM Replacement, Back Panel: adım 2, 1 resimden 1.
    • Unscrew two 5mm Phillips #1 screws.
  3. Asus K53E-BBR3 RAM Replacement: adım 3, 1 resimden 1.
    • Pull down and lift up on the back panel to remove it.
  4. Asus K53E-BBR3 RAM Replacement, RAM: adım 4, 1 resimden 1.
    • After sliding down the back panel you will see three individual compartments with different components. The one to the far right is the RAM.
  5. Asus K53E-BBR3 RAM Replacement: adım 5, 3 resimden 1. Asus K53E-BBR3 RAM Replacement: adım 5, 3 resimden 2. Asus K53E-BBR3 RAM Replacement: adım 5, 3 resimden 3.
    • To remove the RAM stick, locate the silver tabs holding the stick in place.
    • Move the silver tabs so that the detents are no longer holding the RAM in place. Once you've done this, the RAM will pop up and out.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Bradley Anastacio
213 İtibar
1 Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 1-1, Catania Fall 2016 UMass Dartmouth, Team 1-1, Catania Fall 2016 üyesi
UMASSD-CATANIA-F16S1G1
3 Üyeler
7 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 15
Her zaman: 649
