Ana içeriğe geç
Asus K53E-BBR3 Wi-Fi Card Replacement
Neye ihtiyacın var
  1. Asus K53E-BBR3 Wi-Fi Card Replacement, Battery: adım 1, 3 resimden 1. Asus K53E-BBR3 Wi-Fi Card Replacement, Battery: adım 1, 3 resimden 2. Asus K53E-BBR3 Wi-Fi Card Replacement, Battery: adım 1, 3 resimden 3.
    • Place your laptop face down in front of you.
    • Slide the button in the top right corner to the right so that the orange marker is showing.
    • Press the spring loaded latch to release the battery from the computer.
  2. Asus K53E-BBR3 Wi-Fi Card Replacement, Back Panel: adım 2, 1 resimden 1.
    • Unscrew two 5mm Phillips #1 screws.
  3. Asus K53E-BBR3 Wi-Fi Card Replacement: adım 3, 1 resimden 1.
    • Pull down and lift up on the back panel to remove it.
  4. Asus K53E-BBR3 Wi-Fi Card Replacement, Wi-Fi Card: adım 4, 1 resimden 1.
    • Disconnect the wires by pulling them up.
  5. Asus K53E-BBR3 Wi-Fi Card Replacement: adım 5, 1 resimden 1.
    • Unscrew the two 5mm Phillips #1 screws.
  6. Asus K53E-BBR3 Wi-Fi Card Replacement: adım 6, 1 resimden 1.
    • Lift up the Wi-Fi card and remove it.
Sonuç
Liza Sousa
355 İtibar
3 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 1-1, Catania Fall 2016 UMass Dartmouth, Team 1-1, Catania Fall 2016 üyesi
UMASSD-CATANIA-F16S1G1
3 Üyeler
7 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 10
Her zaman: 675
