Ana içeriğe geç
Asus K53E-BBR7 Optical Drive Replacement
Neye ihtiyacın var
  1. Asus K53E-BBR7 Optical Drive Replacement, Optical Drive: adım 1, 3 resimden 1. Asus K53E-BBR7 Optical Drive Replacement, Optical Drive: adım 1, 3 resimden 2. Asus K53E-BBR7 Optical Drive Replacement, Optical Drive: adım 1, 3 resimden 3.
    • Push the two locking mechanisms at the top of your laptop away from each other.
    • Pull the battery away from your laptop using your hands.
    • The battery of this laptop is missing.
  2. Asus K53E-BBR7 Optical Drive Replacement: adım 2, 1 resimden 1.
    • Remove the two black 7.0 mm Phillips #0 screws from the back cover of your laptop.
  3. Asus K53E-BBR7 Optical Drive Replacement: adım 3, 1 resimden 1.
    • Remove the back panel by sliding the panel downwards with your hands.
  4. Asus K53E-BBR7 Optical Drive Replacement: adım 4, 1 resimden 1.
    • Use your Phillips #0 screwdriver to remove the four 7.0 mm Phillips #0 screws surrounding the hard drive.
    • Use your hands to slowly pull the hard drive out of your laptop.
    • The hard drive of this laptop is missing.
  5. Asus K53E-BBR7 Optical Drive Replacement: adım 5, 2 resimden 1. Asus K53E-BBR7 Optical Drive Replacement: adım 5, 2 resimden 2.
    • Using your Phillips #0 screwdriver, remove the following seventeen screws from your laptop:
    • Sixteen black 7.0 mm Phillips #0 screws
    • One silver 4.0 mm Phillips #0 screw
  6. Asus K53E-BBR7 Optical Drive Replacement: adım 6, 3 resimden 1. Asus K53E-BBR7 Optical Drive Replacement: adım 6, 3 resimden 2. Asus K53E-BBR7 Optical Drive Replacement: adım 6, 3 resimden 3.
    • Flip the laptop over and open the lid to reveal the keyboard.
    • Insert the blue prying tool into each of the five tabs located at the top of the keyboard, pulling upwards on the keyboard to separate it from the palm rest.
    • Once the top of the keyboard has been separated from the device, slowly begin pulling the keyboard away from the laptop using your hands.
    • A silver ribbon cable is connected to the keyboard and the palm rest of the laptop. Removing the keyboard quickly may tear the silver ribbon cable, causing harm to your device.
  7. Asus K53E-BBR7 Optical Drive Replacement: adım 7, 1 resimden 1.
    • Using your fingers, gently disconnect the silver ribbon cable from the laptop by pulling the cable out of the slot and to the right.
    • When separating the ribbon cable from the laptop, be gentle. Improperly removing the ribbon cable from the device can damage the laptop.
  8. Asus K53E-BBR7 Optical Drive Replacement: adım 8, 2 resimden 1. Asus K53E-BBR7 Optical Drive Replacement: adım 8, 2 resimden 2.
    • Remove the single silver 6.0 mm Phillips #0 screw that connects the optical drive to the palm rest.
  9. Asus K53E-BBR7 Optical Drive Replacement: adım 9, 2 resimden 1. Asus K53E-BBR7 Optical Drive Replacement: adım 9, 2 resimden 2.
    • Remove the optical drive from the laptop by pulling it to the right with your hands.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Christina Nelson
274 İtibar
1 Kılavuz yazıldı
Ekip
UW Tacoma, Team 1-3, Rose Fall 2016 UW Tacoma, Team 1-3, Rose Fall 2016 üyesi
UWT-ROSE-F16S1G3
4 Üyeler
4 adet Kılavuz yazıldı
Bir Yorum
Most of these steps are unnecessary to get to the dvd-drive. The keyboard clicks loose without removing these screws too, so only steps 7, 8 and 9 are needed.
Nick - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 13
Her zaman: 2,794
