Giriş
If your hard drive is making a loud clicking noise, has failed, or is slowing down your laptop, it may need replaced. This guide will show you how to quickly remove and disassemble the hard drive from the laptop such that a new one can be installed.
Neye ihtiyacın var
Using a JIS #00 screwdriver, unscrew the two 5 mm screws on either side of the laptop panel.
Using a JIS #00 screwdriver, unscrew the four 5 mm screws fastening the hard drive enclosure to the laptop.
Bir başkası bu kılavuzu tamamladı.
