Ana içeriğe geç
Asus K55N-DS81 Rear Panel Replacement
Neye ihtiyacın var
  1. Asus K55N-DS81 Rear Panel Replacement, Battery: adım 1, 1 resimden 1.
    • Flip the laptop over, such that the bottom of the laptop is facing upwards.
    • Ensure that the laptop is powered off prior to following this guide.
  2. Asus K55N-DS81 Rear Panel Replacement: adım 2, 2 resimden 1. Asus K55N-DS81 Rear Panel Replacement: adım 2, 2 resimden 2.
    • Pull the latch to the right of the battery to the right.
  3. Asus K55N-DS81 Rear Panel Replacement: adım 3, 2 resimden 1. Asus K55N-DS81 Rear Panel Replacement: adım 3, 2 resimden 2.
    • Pull the latch to the left of the battery to the left. Hold the latch open with a finger to prevent it from closing.
  4. Asus K55N-DS81 Rear Panel Replacement: adım 4, 2 resimden 1. Asus K55N-DS81 Rear Panel Replacement: adım 4, 2 resimden 2.
    • While holding the second latch from the previous step, use another hand to reach underneath the battery.
    • Pull the battery upwards and away from the laptop to remove it.
  5. Asus K55N-DS81 Rear Panel Replacement, Rear Panel: adım 5, 2 resimden 1. Asus K55N-DS81 Rear Panel Replacement, Rear Panel: adım 5, 2 resimden 2.
    • Using a JIS #00 screwdriver, unscrew the two 5 mm screws on either side of the laptop panel.
  6. Asus K55N-DS81 Rear Panel Replacement: adım 6, 3 resimden 1. Asus K55N-DS81 Rear Panel Replacement: adım 6, 3 resimden 2. Asus K55N-DS81 Rear Panel Replacement: adım 6, 3 resimden 3.
    • Remove the panel by pushing away from the laptop until the panel is free of the laptop.
    • Lift to remove the panel.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Elliott Beckner
543 İtibar
4 adet Kılavuz yazıldı
Ekip
IUPUI, Team S2-G1, Baechle Fall 2018 IUPUI, Team S2-G1, Baechle Fall 2018 üyesi
IUPUI-BAECHLE-F18S2G1
4 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 9
Son 30 gün: 18
Her zaman: 376
