Giriş
When the RAM is replaced, you will have the ability to easily access frequently used files, boost the speed of your laptop and eliminate error messages. Before you begin, you must ensure that the device is completely powered off and the battery is removed.
Neye ihtiyacın var
Adım 1 Battery
Dikkatli ol: adım 1 yapım altında olarak işaretlenen bir kılavuzdan alınmıştır.
Flip the device over to its back cover.
Use the switches to release the battery from its adapter.
To access the compartment that holds the RAM, flip the laptop so the bottom cover is facing upward and the battery compartment is facing away from you.
2 farklı kişi bu kılavuzu tamamladı.
