Ana içeriğe geç
Asus K55a-si50301p Hard Drive Replacement
Neye ihtiyacın var
  1. Asus K55a-si50301p Hard Drive Replacement, Battery: adım 1, 1 resimden 1.
    • Press and slide the two battery retention clips on either side of the battery towards the unlock position.
  2. Asus K55a-si50301p Hard Drive Replacement: adım 2, 1 resimden 1.
    • Pull the right side retention clip so that the red indicator is showing.
    • The small graphic below the retention clip denotes locked and unlocked positions. The clip will stay put once moved into position.
  3. Asus K55a-si50301p Hard Drive Replacement: adım 3, 1 resimden 1.
    • Pull the retention clip on the left hand side of the laptop away from the battery.
    • Gently pull the battery out with your free hand.
  4. Asus K55a-si50301p Hard Drive Replacement, Lower Back Panel: adım 4, 1 resimden 1.
    • Remove the two 8.5mm screws using a PH0 screwdriver.
  5. Asus K55a-si50301p Hard Drive Replacement: adım 5, 1 resimden 1.
    • Using the iFixit opening tool, gently pry the plastic cover away from its original position.
  6. Asus K55a-si50301p Hard Drive Replacement: adım 6, 1 resimden 1.
    • Gently pull up and then towards you until the plastic cover is free.
  7. Asus K55a-si50301p Hard Drive Replacement, Hard Drive: adım 7, 2 resimden 1. Asus K55a-si50301p Hard Drive Replacement, Hard Drive: adım 7, 2 resimden 2.
    • Remove the (3) screws that hold the hard drive to the case.
  8. Asus K55a-si50301p Hard Drive Replacement: adım 8, 2 resimden 1. Asus K55a-si50301p Hard Drive Replacement: adım 8, 2 resimden 2.
    • Disconnect the SATA link from the hard drive by pulling back on the grey connector.
  9. Asus K55a-si50301p Hard Drive Replacement: adım 9, 1 resimden 1.
    • Remove the two screws from each side of the hard drive tray.
    • Replace the hard drive with a new 2.5" hard drive or solid state drive.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Bir Yorum
So the link you give for the replacement hard drive is for a 3.5 inch drive instead of a 2.5 inch drive
sweal - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 11
Her zaman: 1,136
