Ana içeriğe geç
Asus K55a-si50301p Wifi Card Replacement
Neye ihtiyacın var
  1. Asus K55a-si50301p Wifi Card Replacement, Battery: adım 1, 1 resimden 1.
    • Press and slide the two battery retention clips on either side of the battery towards the unlock position.
  2. Asus K55a-si50301p Wifi Card Replacement: adım 2, 1 resimden 1.
    • Pull the right side retention clip so that the red indicator is showing.
    • The small graphic below the retention clip denotes locked and unlocked positions. The clip will stay put once moved into position.
  3. Asus K55a-si50301p Wifi Card Replacement: adım 3, 1 resimden 1.
    • Pull the retention clip on the left hand side of the laptop away from the battery.
    • Gently pull the battery out with your free hand.
  4. Asus K55a-si50301p Wifi Card Replacement, Lower Back Panel: adım 4, 1 resimden 1.
    • Remove the two 8.5mm screws using a PH0 screwdriver.
  5. Asus K55a-si50301p Wifi Card Replacement: adım 5, 1 resimden 1.
    • Using the iFixit opening tool, gently pry the plastic cover away from its original position.
  6. Asus K55a-si50301p Wifi Card Replacement: adım 6, 1 resimden 1.
    • Gently pull up and then towards you until the plastic cover is free.
  7. Asus K55a-si50301p Wifi Card Replacement, Wifi Card: adım 7, 1 resimden 1.
    • Remove the white and black wires from the card.
    • This does not require much force. Simply squeeze on the sides of the connector and allow the end to pop off.
  8. Asus K55a-si50301p Wifi Card Replacement: adım 8, 1 resimden 1.
    • Remove the two 9mm Phillips #1 screws from the wifi card.
  9. Asus K55a-si50301p Wifi Card Replacement: adım 9, 1 resimden 1.
    • After unscrewing lift gently to remove.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 19
Her zaman: 786
