Ana içeriğe geç
Asus M32BF-US002T RAM Replacement
Neye ihtiyacın var
  1. Asus M32BF-US002T RAM Replacement, RAM: adım 1, 2 resimden 1. Asus M32BF-US002T RAM Replacement, RAM: adım 1, 2 resimden 2.
    • The side panel is located on the left side of the computer.
    • The 2nd image shows the correct side we will be working on.
  2. Asus M32BF-US002T RAM Replacement: adım 2, 3 resimden 1. Asus M32BF-US002T RAM Replacement: adım 2, 3 resimden 2. Asus M32BF-US002T RAM Replacement: adım 2, 3 resimden 3.
    • Face the back of the desktop towards you on a flat work service.
    • Use the Phillips #00 to remove the two 3.5 mm screws on the edge of the side panel.
  3. Asus M32BF-US002T RAM Replacement: adım 3, 2 resimden 1. Asus M32BF-US002T RAM Replacement: adım 3, 2 resimden 2.
    • Pull the small tab on the left side panel.
    • Continue to pull gently until you hear a click sound, then remove the side panel.
  4. Asus M32BF-US002T RAM Replacement: adım 4, 3 resimden 1. Asus M32BF-US002T RAM Replacement: adım 4, 3 resimden 2. Asus M32BF-US002T RAM Replacement: adım 4, 3 resimden 3.
    • Locate the RAM modules.
    • They are thin, long, green, and rectangle shaped.
  5. Asus M32BF-US002T RAM Replacement: adım 5, 3 resimden 1. Asus M32BF-US002T RAM Replacement: adım 5, 3 resimden 2. Asus M32BF-US002T RAM Replacement: adım 5, 3 resimden 3.
    • Unlock the locks that are holding the RAM module down, by pushing them downwards.
    • Although not shown in the first picture, there is also a lock at the bottom and can be seen on picture 3.
  6. Asus M32BF-US002T RAM Replacement: adım 6, 2 resimden 1. Asus M32BF-US002T RAM Replacement: adım 6, 2 resimden 2.
    • Pull the RAM straight out.
    • Wiggling the RAM out of its slot may cause damage to the RAM module, or the RAM slot itself. Pull straight out!
  7. Asus M32BF-US002T RAM Replacement: adım 7, 1 resimden 1.
    • Before installing the new RAM, ensure the slots have been unlocked as seen in this picture.
    • You can tell it is unlocked when the lock looks like it has been pushed away from the slot.
    • If you are adding an additional RAM module, ensure the 2nd RAM slot is unlocked as well.
  8. Asus M32BF-US002T RAM Replacement: adım 8, 2 resimden 1. Asus M32BF-US002T RAM Replacement: adım 8, 2 resimden 2.
    • Before installing, ensure the gap on the RAM module aligns with the notch on the RAM slot.
  9. Asus M32BF-US002T RAM Replacement: adım 9, 1 resimden 1.
    • Align the gap on the RAM module with the notch on the RAM slot.
    • Push straight down until you hear a click or until the locks have locked on their own.
    • An uncomfortable amount of force may be needed in order to successfully install the RAM.
  10. Asus M32BF-US002T RAM Replacement: adım 10, 3 resimden 1. Asus M32BF-US002T RAM Replacement: adım 10, 3 resimden 2. Asus M32BF-US002T RAM Replacement: adım 10, 3 resimden 3.
    • Grab the side panel, and place it on the side of the computer.
    • Slide the side panel to the right to lock the side panel.
  11. Asus M32BF-US002T RAM Replacement: adım 11, 2 resimden 1. Asus M32BF-US002T RAM Replacement: adım 11, 2 resimden 2.
    • Using your Phillips #00 screwdriver, take the screws from Step 2 and screw them back onto the side panel.
    • You have successfully installed RAM into your desktop computer! You are now finished.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Shaun Pangilinan
247 İtibar
1 Kılavuz yazıldı
Ekip
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 7
Son 30 gün: 50
Her zaman: 1,105
