Ana içeriğe geç
Asus M51E-B2 Swivel Camera Replacement
Neye ihtiyacın var
  1. Asus M51E-B2  Swivel Camera Replacement, Swivel Camera: adım 1, 1 resimden 1.
    • Open the laptop.
    • Press and hold the power button until the laptop powers off.
  2. Asus M51E-B2  Swivel Camera Replacement: adım 2, 2 resimden 1. Asus M51E-B2  Swivel Camera Replacement: adım 2, 2 resimden 2.
    • Use a metal spudger prying tool to remove the outer screen cover of the laptop.
    • Gently work your way clockwise around the outer part of the screen.
  3. Asus M51E-B2  Swivel Camera Replacement: adım 3, 2 resimden 1. Asus M51E-B2  Swivel Camera Replacement: adım 3, 2 resimden 2.
    • Use the Phillips PH0 head screwdriver to remove the two 2.5 mm screws located on the left side of the camera.
    • Use the Phillips PH0 head screwdriver to remove the one 2.5 millimeter screw that goes through the left side of the camera.
  4. Asus M51E-B2  Swivel Camera Replacement: adım 4, 1 resimden 1.
    • Find the wiring harness on the right side of the camera.
    • Using your fingers, gently remove the wiring harness connected to the right side of the camera.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 9
Her zaman: 272
