Ana içeriğe geç
Asus MeMO Pad 7 ME170C Battery Replacement
Neye ihtiyacın var
  1. Asus MeMO Pad 7 ME170C  Battery Replacement, Battery: adım 1, 3 resimden 1. Asus MeMO Pad 7 ME170C  Battery Replacement, Battery: adım 1, 3 resimden 2. Asus MeMO Pad 7 ME170C  Battery Replacement, Battery: adım 1, 3 resimden 3.
    • Before beginning to disassemble, Power off the device.
    • Excessive force can result in damaged or cracked screen. Be Gentle.
    • Gently wedge a Jimmy into the seam of the device.
    • Gently pry the Jimmy all around the seam until the back panel is detached.
  2. Asus MeMO Pad 7 ME170C  Battery Replacement: adım 2, 3 resimden 1. Asus MeMO Pad 7 ME170C  Battery Replacement: adım 2, 3 resimden 2. Asus MeMO Pad 7 ME170C  Battery Replacement: adım 2, 3 resimden 3.
    • Locate the black bundle cable connector attached to the battery of the phone.
    • Do not push down. Slide in a forward motion to avoid breaking any inner pieces.
    • Using a plastic opening tool, gently slide the black bundle cable connector towards the battery in a back and forth motion until loosened and it slides out of connection port.
  3. Asus MeMO Pad 7 ME170C  Battery Replacement: adım 3, 3 resimden 1. Asus MeMO Pad 7 ME170C  Battery Replacement: adım 3, 3 resimden 2. Asus MeMO Pad 7 ME170C  Battery Replacement: adım 3, 3 resimden 3.
    • Using a plastic opening tool, pry out the batteries to loosen them out.
    • The battery will be pried out of its port.
    • Lift the battery out of its port
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 21
Her zaman: 3,146
