Ana içeriğe geç
Asus MeMO Pad 7 ME170C Motherboard Replacement
Neye ihtiyacın var
  1. Asus MeMO Pad 7 ME170C  Motherboard  Replacement, Motherboard: adım 1, 3 resimden 1. Asus MeMO Pad 7 ME170C  Motherboard  Replacement, Motherboard: adım 1, 3 resimden 2. Asus MeMO Pad 7 ME170C  Motherboard  Replacement, Motherboard: adım 1, 3 resimden 3.
    • Power off the device before disassembly.
    • Be gentle; excessive force can result in a damaged or cracked screen.
    • Gently pry a Jimmy all around the seam of the device until the back panel detaches.
  2. Asus MeMO Pad 7 ME170C  Motherboard  Replacement: adım 2, 3 resimden 1. Asus MeMO Pad 7 ME170C  Motherboard  Replacement: adım 2, 3 resimden 2. Asus MeMO Pad 7 ME170C  Motherboard  Replacement: adım 2, 3 resimden 3.
    • Use an iFixit opening tool to gently push the black bundle cable connector in a forward motion until it loosens without pushing down on the bundle cable connector.
  3. Asus MeMO Pad 7 ME170C  Motherboard  Replacement: adım 3, 3 resimden 1. Asus MeMO Pad 7 ME170C  Motherboard  Replacement: adım 3, 3 resimden 2. Asus MeMO Pad 7 ME170C  Motherboard  Replacement: adım 3, 3 resimden 3.
    • Use the plastic opening tool to pry around the edges of the battery.
    • The battery should be laying freely in its port.
    • Lift the battery out of its port.
  4. Asus MeMO Pad 7 ME170C  Motherboard  Replacement: adım 4, 3 resimden 1. Asus MeMO Pad 7 ME170C  Motherboard  Replacement: adım 4, 3 resimden 2. Asus MeMO Pad 7 ME170C  Motherboard  Replacement: adım 4, 3 resimden 3.
    • Use a plastic opening tool to slide the white cable connector completely out of the port.
  5. Asus MeMO Pad 7 ME170C  Motherboard  Replacement: adım 5, 3 resimden 1. Asus MeMO Pad 7 ME170C  Motherboard  Replacement: adım 5, 3 resimden 2. Asus MeMO Pad 7 ME170C  Motherboard  Replacement: adım 5, 3 resimden 3.
    Bu adımda kullanılan alet:
    Satın Al
    • Flip up the beige clip to loosen the cable.
    • Use the wide nosed tweezers to pinch the blue tab attached to the ribbon cable.
    • Pull the blue tab gently in a lateral motion until it is completely out of its port.
  6. Asus MeMO Pad 7 ME170C  Motherboard  Replacement: adım 6, 3 resimden 1. Asus MeMO Pad 7 ME170C  Motherboard  Replacement: adım 6, 3 resimden 2. Asus MeMO Pad 7 ME170C  Motherboard  Replacement: adım 6, 3 resimden 3.
    • Use the wide nosed tweezers to gently pull out the orange ribbon inserted in the port on the motherboard.
  7. Asus MeMO Pad 7 ME170C  Motherboard  Replacement: adım 7, 3 resimden 1. Asus MeMO Pad 7 ME170C  Motherboard  Replacement: adım 7, 3 resimden 2. Asus MeMO Pad 7 ME170C  Motherboard  Replacement: adım 7, 3 resimden 3.
    • Use a plastic opening tool to push the white cable connector out of its port in a side to side motion.
  8. Asus MeMO Pad 7 ME170C  Motherboard  Replacement: adım 8, 2 resimden 1. Asus MeMO Pad 7 ME170C  Motherboard  Replacement: adım 8, 2 resimden 2.
    • Use the Phillips #000 screwdriver to unscrew the seven screws.
    • There should be two silver and five black screws.
  9. Asus MeMO Pad 7 ME170C  Motherboard  Replacement: adım 9, 2 resimden 1. Asus MeMO Pad 7 ME170C  Motherboard  Replacement: adım 9, 2 resimden 2.
    • Once the screws are removed, the speaker component will be loosely laying in the track.
    • Use the metal spudger tool to remove the speaker by gently lifting the edge of it.
  10. Asus MeMO Pad 7 ME170C  Motherboard  Replacement: adım 10, 3 resimden 1. Asus MeMO Pad 7 ME170C  Motherboard  Replacement: adım 10, 3 resimden 2. Asus MeMO Pad 7 ME170C  Motherboard  Replacement: adım 10, 3 resimden 3.
    • Remove the silver tape on one corner with the needle nosed tweezers, and remove the tape from the motherboard.
  11. Asus MeMO Pad 7 ME170C  Motherboard  Replacement: adım 11, 3 resimden 1. Asus MeMO Pad 7 ME170C  Motherboard  Replacement: adım 11, 3 resimden 2. Asus MeMO Pad 7 ME170C  Motherboard  Replacement: adım 11, 3 resimden 3.
    • Use the needle nosed tweezers to gently pull both of the orange ribbon cables out of their ports.
  12. Asus MeMO Pad 7 ME170C  Motherboard  Replacement: adım 12, 3 resimden 1. Asus MeMO Pad 7 ME170C  Motherboard  Replacement: adım 12, 3 resimden 2. Asus MeMO Pad 7 ME170C  Motherboard  Replacement: adım 12, 3 resimden 3.
    • Use the Phillips #000 screwdriver to unscrew all five screws.
  13. Asus MeMO Pad 7 ME170C  Motherboard  Replacement: adım 13, 2 resimden 1. Asus MeMO Pad 7 ME170C  Motherboard  Replacement: adım 13, 2 resimden 2.
    • To uninstall the motherboard, use the metal spudger tool to lift it out of the device.
Sonuç
6 farklı kişi bu kılavuzu tamamladı.
Bir Yorum
You are amazing!! Please make the tutorial "how change ASUS ME170 Touch Screen Digitizer". Thanks!!!
Walter Tejerina - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 11
Son 30 gün: 17
Her zaman: 3,318
