Ana içeriğe geç
Asus MeMO Pad 7 ME170C Speaker Replacement
Neye ihtiyacın var
  1. Asus MeMO Pad 7 ME170C Speaker Replacement, Speaker: adım 1, 3 resimden 1. Asus MeMO Pad 7 ME170C Speaker Replacement, Speaker: adım 1, 3 resimden 2. Asus MeMO Pad 7 ME170C Speaker Replacement, Speaker: adım 1, 3 resimden 3.
    • Before beginning to disassemble the device, power it off.
    • Make sure to be gentle with the device. Excessive force can result in a damaged screen.
    • Using the Jimmy tool, gently wedge it into the seam of the device at the side.
    • Pry the Jimmy tool gently all around the seam. Use up and down motions until the back panel is detached.
  2. Asus MeMO Pad 7 ME170C Speaker Replacement: adım 2, 3 resimden 1. Asus MeMO Pad 7 ME170C Speaker Replacement: adım 2, 3 resimden 2. Asus MeMO Pad 7 ME170C Speaker Replacement: adım 2, 3 resimden 3.
    • From the top of the tablet, locate the white cable connector.
    • It is inserted in a black port on the motherboard.
    • Use the blue plastic opening tool to push the white cable connector out of the port.
    • Push the cable in a sideways motion towards the top of the device.
  3. Asus MeMO Pad 7 ME170C Speaker Replacement: adım 3, 2 resimden 1. Asus MeMO Pad 7 ME170C Speaker Replacement: adım 3, 2 resimden 2.
    • Use the Phillips #000 screwdriver to remove the seven screws.
    • There should be two silver and five black screws for a total of seven screws.
  4. Asus MeMO Pad 7 ME170C Speaker Replacement: adım 4, 2 resimden 1. Asus MeMO Pad 7 ME170C Speaker Replacement: adım 4, 2 resimden 2.
    • Use the slender, metal spudger tool to gently lift up the edge of the speaker to remove the device.
Sonuç
Bir başkası bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 14
Her zaman: 700
