Ana içeriğe geç
Asus MeMO Pad 7 ME176C LCD Screen Assembly Replacement
Neye ihtiyacın var
  1. Asus MeMO Pad 7 ME176C LCD Screen Assembly Replacement, LCD Screen Assembly: adım 1, 2 resimden 1. Asus MeMO Pad 7 ME176C LCD Screen Assembly Replacement, LCD Screen Assembly: adım 1, 2 resimden 2.
    • Insert plastic opening tool in between screen and back cover to create initial separation between the two.
    • Then run plastic opening tool along end of screen to fully separate back cover from screen.
  2. Asus MeMO Pad 7 ME176C LCD Screen Assembly Replacement: adım 2, 2 resimden 1. Asus MeMO Pad 7 ME176C LCD Screen Assembly Replacement: adım 2, 2 resimden 2.
    • Remove screws (2.6mm) connecting speaker to hard frame with Phillips head screw driver (PH000).
  3. Asus MeMO Pad 7 ME176C LCD Screen Assembly Replacement: adım 3, 1 resimden 1.
    Bu adımda kullanılan alet:
    Satın Al
    • Disconnect speaker wire from motherboard using metal pronged tweezers.
  4. Asus MeMO Pad 7 ME176C LCD Screen Assembly Replacement: adım 4, 1 resimden 1.
    • Remove the screws (2.6mm) connecting the motherboard and battery tray to the hard frame with Phillip's head screw driver (PH000).
  5. Asus MeMO Pad 7 ME176C LCD Screen Assembly Replacement: adım 5, 2 resimden 1. Asus MeMO Pad 7 ME176C LCD Screen Assembly Replacement: adım 5, 2 resimden 2.
    • Remove the black bundle battery connector from the motherboard using plastic opening tools.
  6. Asus MeMO Pad 7 ME176C LCD Screen Assembly Replacement: adım 6, 2 resimden 1. Asus MeMO Pad 7 ME176C LCD Screen Assembly Replacement: adım 6, 2 resimden 2.
    • Use plastic opener tool to disconnect ZIF connectors as shown.
  7. Asus MeMO Pad 7 ME176C LCD Screen Assembly Replacement: adım 7, 3 resimden 1. Asus MeMO Pad 7 ME176C LCD Screen Assembly Replacement: adım 7, 3 resimden 2. Asus MeMO Pad 7 ME176C LCD Screen Assembly Replacement: adım 7, 3 resimden 3.
    • Remove speaker housing to expose ZIF connection underneath.
    • Then using metal tweezers disconnect the ZIF connector.
  8. Asus MeMO Pad 7 ME176C LCD Screen Assembly Replacement: adım 8, 2 resimden 1. Asus MeMO Pad 7 ME176C LCD Screen Assembly Replacement: adım 8, 2 resimden 2.
    • Remove display and button connections from motherboard using metal tweezers.
  9. Asus MeMO Pad 7 ME176C LCD Screen Assembly Replacement: adım 9, 2 resimden 1. Asus MeMO Pad 7 ME176C LCD Screen Assembly Replacement: adım 9, 2 resimden 2.
    • Remove unscrewed battery tray from main frame.
  10. Asus MeMO Pad 7 ME176C LCD Screen Assembly Replacement: adım 10, 2 resimden 1. Asus MeMO Pad 7 ME176C LCD Screen Assembly Replacement: adım 10, 2 resimden 2.
    • Remove motherboard from hard frame.
    • When removing the motherboard make sure all screws that attach motherboard to hardframe are removed and to release plastic tab as shown in image.
  11. Asus MeMO Pad 7 ME176C LCD Screen Assembly Replacement: adım 11, 2 resimden 1. Asus MeMO Pad 7 ME176C LCD Screen Assembly Replacement: adım 11, 2 resimden 2.
    • Peel off button sensors off the side of the hard frame.
  12. Asus MeMO Pad 7 ME176C LCD Screen Assembly Replacement: adım 12, 3 resimden 1. Asus MeMO Pad 7 ME176C LCD Screen Assembly Replacement: adım 12, 3 resimden 2. Asus MeMO Pad 7 ME176C LCD Screen Assembly Replacement: adım 12, 3 resimden 3.
    • Apply slight pressure on camera to break adhesive to finish screen disassembly processes.
Sonuç
Nejad Harara
110 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team S6-G3, Banghart Fall 2017 Cal Poly, Team S6-G3, Banghart Fall 2017 üyesi
CPSU-BANGHART-F17S6G3
5 Üyeler
9 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 10
Her zaman: 1,686
