Ana içeriğe geç
Asus MeMO Pad 7 ME176C Speaker Replacement
Neye ihtiyacın var
  1. Asus MeMO Pad 7 ME176C Speaker Replacement, Speakers: adım 1, 2 resimden 1. Asus MeMO Pad 7 ME176C Speaker Replacement, Speakers: adım 1, 2 resimden 2.
    Bu adımda kullanılan alet:
    iFixit Opening Tool
    $1.99
    • Make sure the device is turned off.
    • Carefully insert the opening tool on the edge of the phone.
    • Slowly lift up the panel from the device and repeat the process on the other side.
  2. Asus MeMO Pad 7 ME176C Speaker Replacement: adım 2, 3 resimden 1. Asus MeMO Pad 7 ME176C Speaker Replacement: adım 2, 3 resimden 2. Asus MeMO Pad 7 ME176C Speaker Replacement: adım 2, 3 resimden 3.
    • To disconnect the ZIF connectors. Place the metal spudger underneath the ZIF cable and gently pull it outward.
    • ZIF connectors are fragile, so work with caution.
  3. Asus MeMO Pad 7 ME176C Speaker Replacement: adım 3, 3 resimden 1. Asus MeMO Pad 7 ME176C Speaker Replacement: adım 3, 3 resimden 2. Asus MeMO Pad 7 ME176C Speaker Replacement: adım 3, 3 resimden 3.
    • The battery connector is located on the right-hand side of the device
    • To disconnect the battery connector. Use tweezers, and carefully lift up the wire.
    • Remove the battery.
  4. Asus MeMO Pad 7 ME176C Speaker Replacement: adım 4, 1 resimden 1.
    • Using a Philips Head Screwdriver PH000, locate the 2.6mm screws and gently unscrew them .
    • Place these screws somewhere you will remember.
    • Applying too much pressure onto the screen may cause it to break.
  5. Asus MeMO Pad 7 ME176C Speaker Replacement: adım 5, 3 resimden 1. Asus MeMO Pad 7 ME176C Speaker Replacement: adım 5, 3 resimden 2. Asus MeMO Pad 7 ME176C Speaker Replacement: adım 5, 3 resimden 3.
    • Using tweezers, disconnect the speaker cable connected to the motherboard.
    • Be sure not to damage other components on the motherboard.
    • After that remove the speaker system completely.
  6. Asus MeMO Pad 7 ME176C Speaker Replacement: adım 6, 1 resimden 1.
    • Now you can attach a new speaker!
Sonuç
Maxime
101 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team S6-G3, Banghart Fall 2017 Cal Poly, Team S6-G3, Banghart Fall 2017 üyesi
CPSU-BANGHART-F17S6G3
5 Üyeler
9 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 254
