Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
Bu adımda kullanılan alet:iFixit Opening Tool$1.99-
Make sure the device is turned off.
Carefully insert the opening tool on the edge of the phone.
Slowly lift up the panel from the device and repeat the process on the other side.
To disconnect the ZIF connectors. Place the metal spudger underneath the ZIF cable and gently pull it outward.
To disconnect the battery connector. Use tweezers, and carefully lift up the wire.
Remove the battery.
Using a Philips Head Screwdriver PH000, locate the 2.6mm screws and gently unscrew them .
Using tweezers, disconnect the speaker cable connected to the motherboard.
After that remove the speaker system completely.
