Giriş
Use this guide to replace a faulty battery in you ASUS MeMO Pad 8.
Neye ihtiyacın var
Insert a plastic opening tool into the seam between the rear case and the screen.
Work the plastic opening tool around the perimeter of the device to completely remove the rear case.
Use the flat end of the nylon spudger to flip up the retaining flap of the Zero Insertion Force (ZIF) connector holding the orange motherboard ribbon cable in place.
7 farklı kişi bu kılavuzu tamamladı.
2 Yorum
Great instructions and easy disassembly/reassembly. Photos really helped!
