Giriş
This guide will direct you in replacing the entire speaker assembly for the tablet. The guide will require a few simple steps and removing a few small screws form the device.
Neye ihtiyacın var
Adım 1 Remove Rear Panel
Dikkatli ol: adımlar 1-4 yapım altında olarak işaretlenen bir kılavuzdan alınmıştır.
Carefully remove the back panel by using a plastic opening tool to remove the panel off the device.
Pull the back panel away from the device.
Using a spudger carefully pry the battery up. It is glued down so slight pressure may be needed.
Unscrew two Philip's #000 2 mm screws located on the left and right side of the speaker housing.
3 farklı kişi bu kılavuzu tamamladı.
