Ana içeriğe geç
Asus MeMO Pad HD 8 ME180A Battery Replacement
Neye ihtiyacın var
  1. Asus MeMO Pad HD 8 ME180A Battery Replacement, Battery: adım 1, 2 resimden 1. Asus MeMO Pad HD 8 ME180A Battery Replacement, Battery: adım 1, 2 resimden 2.
    • Use a plastic opening tool to separate the back half from the front half.
    • Pull the back panel away from the device.
    • The volume buttons can fall out of the case. Be careful not to lose them.
  2. Asus MeMO Pad HD 8 ME180A Battery Replacement: adım 2, 1 resimden 1.
    Bu adımda kullanılan alet:
    Anti-Static Wrist Strap
    $7.95
    Satın Al
  3. Asus MeMO Pad HD 8 ME180A Battery Replacement: adım 3, 3 resimden 1. Asus MeMO Pad HD 8 ME180A Battery Replacement: adım 3, 3 resimden 2. Asus MeMO Pad HD 8 ME180A Battery Replacement: adım 3, 3 resimden 3.
    • Lift the white bar on the ZIF connector and pull the metal connector out.
  4. Asus MeMO Pad HD 8 ME180A Battery Replacement: adım 4, 2 resimden 1. Asus MeMO Pad HD 8 ME180A Battery Replacement: adım 4, 2 resimden 2.
    • Using your spudger, press down on the two spots shown in order to release the cables.
    • Ensure that the touchscreen cables are fully disconnected.
  5. Asus MeMO Pad HD 8 ME180A Battery Replacement: adım 5, 2 resimden 1. Asus MeMO Pad HD 8 ME180A Battery Replacement: adım 5, 2 resimden 2.
    • Using a PH#0 screwdriver, remove the twelve silver 3.2 mm screws.
    • Pull the battery out.
Sonuç
Rebecca Ellerhorst
561 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 2-5, Nance Fall 2016 USF Tampa, Team 2-5, Nance Fall 2016 üyesi
USFT-NANCE-F16S2G5
3 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 846
