Ana içeriğe geç
Asus MeMO Pad HD 8 ME180A Motherboard Replacement
Neye ihtiyacın var
  1. Asus MeMO Pad HD 8 ME180A Motherboard Replacement, Battery: adım 1, 2 resimden 1. Asus MeMO Pad HD 8 ME180A Motherboard Replacement, Battery: adım 1, 2 resimden 2.
    • Use a plastic opening tool to separate the back half from the front half.
    • Pull the back panel away from the device.
    • The volume buttons can fall out of the case. Be careful not to lose them.
  2. Asus MeMO Pad HD 8 ME180A Motherboard Replacement: adım 2, 1 resimden 1.
    Bu adımda kullanılan alet:
    Anti-Static Wrist Strap
    $7.95
    Satın Al
  3. Asus MeMO Pad HD 8 ME180A Motherboard Replacement: adım 3, 3 resimden 1. Asus MeMO Pad HD 8 ME180A Motherboard Replacement: adım 3, 3 resimden 2. Asus MeMO Pad HD 8 ME180A Motherboard Replacement: adım 3, 3 resimden 3.
    • Lift the white bar on the ZIF connector and pull the metal connector out.
  4. Asus MeMO Pad HD 8 ME180A Motherboard Replacement: adım 4, 2 resimden 1. Asus MeMO Pad HD 8 ME180A Motherboard Replacement: adım 4, 2 resimden 2.
    • Using your spudger, press down on the two spots shown in order to release the cables.
    • Ensure that the touchscreen cables are fully disconnected.
  5. Asus MeMO Pad HD 8 ME180A Motherboard Replacement: adım 5, 2 resimden 1. Asus MeMO Pad HD 8 ME180A Motherboard Replacement: adım 5, 2 resimden 2.
    • Using a PH#0 screwdriver, remove the twelve silver 3.2 mm screws.
    • Pull the battery out.
  6. Asus MeMO Pad HD 8 ME180A Motherboard Replacement, Motherboard: adım 6, 1 resimden 1.
    • Disconnect GPS Antenna cable.
  7. Asus MeMO Pad HD 8 ME180A Motherboard Replacement: adım 7, 1 resimden 1.
    • Flip the latch and pull the ribbon cable to disconnect the ZIF connector.
  8. Asus MeMO Pad HD 8 ME180A Motherboard Replacement: adım 8, 1 resimden 1.
  9. Asus MeMO Pad HD 8 ME180A Motherboard Replacement: adım 9, 2 resimden 1. Asus MeMO Pad HD 8 ME180A Motherboard Replacement: adım 9, 2 resimden 2.
    • Use a PH#0 screwdriver to unscrew the six 3.0 mm black screws.
    • Lift the motherboard straight up to remove.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Rebecca Ellerhorst
561 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 2-5, Nance Fall 2016 USF Tampa, Team 2-5, Nance Fall 2016 üyesi
USFT-NANCE-F16S2G5
3 Üyeler
10 adet Kılavuz yazıldı
2 Yorum
Où je peux avoir une carte mère pour asus memo pad8 me 180
David Leblanc - Yanıt
Shouldn’t there be a step to handle the camera?
Haggai Eran - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 3
Her zaman: 748
