Ana içeriğe geç
Asus MeMo Pad 10 ME102A Back Panel Replacement
Neye ihtiyacın var
    1. Asus MeMo Pad 10 ME102A Back Panel Replacement, Back Panel: adım 1, 1 resimden 1.
      • Insert the blue plastic opening tool into the seam between the back panel and the chassis.
      • When removing the back panel, remember to keep the device face down on a flat surface in order to prevent dropping the device or anything inside of the device.
      FixBot'a Sor
      Yorum Ekle
    2. Asus MeMo Pad 10 ME102A Back Panel Replacement: adım 2, 1 resimden 1.
      • Slide the plastic opener around the tablet. There will be spots of resistance. These should gently pop open as the tool slides through the seam.
      FixBot'a Sor
      Yorum Ekle
    3. Asus MeMo Pad 10 ME102A Back Panel Replacement: adım 3, 1 resimden 1.
      • After all of the clips have been opened, the back panel should be free to remove by hand
      FixBot'a Sor
      Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Andreas Niederer
426 İtibar
2 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 11-3, Blackwell Fall 2016 USF Tampa, Team 11-3, Blackwell Fall 2016 üyesi
USFT-BLACKWELL-F16S11G3
4 Üyeler
10 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 9
Son 30 gün: 30
Her zaman: 2,067
