Giriş
This guide shows how to replace the motherboard on Asus MeMo Pad 10 ME102A
Neye ihtiyacın var
Insert the blue plastic opening tool into the seam between the back panel and the chassis.
The right-hand speaker is labeled ME102A-R and is located by the battery plug. This is the first speaker removed in this guide, however if the left-hand speaker is the only one you need to replace please skip down to the left-hand speaker section.
Unplug the speaker cable by gently pushing it parallel to the motherboard with the flat side of the blue plastic opening tool.
The left-hand speaker is designated by the lettering ME102A-L and is located by the silver and blue ribbon cable running across the top of the battery.
Remove the Ribbon cable labeled CN2 by gently prying up the white latch of the black and white plugs by using the small blue plastic opening tool.
Remove the Ribbon cable labeled CN1 by gently prying up the white latch of the black and white plugs by using the small blue plastic opening tool.
Use the blue plastic opening tool to lift open the black latch connecting the blue ribbon cable to the motherboard.
5 farklı kişi bu kılavuzu tamamladı.
