Ana içeriğe geç
Asus MeMo Pad 10 ME102A Motherboard Replacement
Neye ihtiyacın var
  1. Asus MeMo Pad 10 ME102A Motherboard Replacement, Back Panel: adım 1, 1 resimden 1.
    • Insert the blue plastic opening tool into the seam between the back panel and the chassis.
    • When removing the back panel, remember to keep the device face down on a flat surface in order to prevent dropping the device or anything inside of the device.
  2. Asus MeMo Pad 10 ME102A Motherboard Replacement: adım 2, 1 resimden 1.
    • Slide the plastic opener around the tablet. There will be spots of resistance. These should gently pop open as the tool slides through the seam.
  3. Asus MeMo Pad 10 ME102A Motherboard Replacement: adım 3, 1 resimden 1.
    • After all of the clips have been opened, the back panel should be free to remove by hand
  4. Asus MeMo Pad 10 ME102A Motherboard Replacement, Speakers: adım 4, 1 resimden 1.
    • The right-hand speaker is labeled ME102A-R and is located by the battery plug. This is the first speaker removed in this guide, however if the left-hand speaker is the only one you need to replace please skip down to the left-hand speaker section.
    • Unplug the speaker cable by gently pushing it parallel to the motherboard with the flat side of the blue plastic opening tool.
  5. Asus MeMo Pad 10 ME102A Motherboard Replacement: adım 5, 1 resimden 1.
    • Unscrew the M2x4mm screw with the PH00 screwdriver attachment.
  6. Asus MeMo Pad 10 ME102A Motherboard Replacement: adım 6, 1 resimden 1.
    • Lift the speaker up by the end opposing the steel latch and slide it out from under the steel latch. The speaker has now been removed.
  7. Asus MeMo Pad 10 ME102A Motherboard Replacement: adım 7, 2 resimden 1. Asus MeMo Pad 10 ME102A Motherboard Replacement: adım 7, 2 resimden 2.
    • The left-hand speaker is designated by the lettering ME102A-L and is located by the silver and blue ribbon cable running across the top of the battery.
    • Remove the Ribbon cable labeled CN2 by gently prying up the white latch of the black and white plugs by using the small blue plastic opening tool.
    • Remove the Ribbon cable labeled CN1 by gently prying up the white latch of the black and white plugs by using the small blue plastic opening tool.
  8. Asus MeMo Pad 10 ME102A Motherboard Replacement: adım 8, 1 resimden 1.
  9. Asus MeMo Pad 10 ME102A Motherboard Replacement: adım 9, 1 resimden 1.
  10. Asus MeMo Pad 10 ME102A Motherboard Replacement: adım 10, 1 resimden 1.
  11. Asus MeMo Pad 10 ME102A Motherboard Replacement, Motherboard: adım 11, 1 resimden 1.
    • Use the blue plastic opening tool to lift open the black latch connecting the blue ribbon cable to the motherboard.
  12. Asus MeMo Pad 10 ME102A Motherboard Replacement: adım 12, 1 resimden 1.
    • Using the blue plastic opening tool unplug the battery plug by gently pushing the plug out parallel to the motherboard.
  13. Asus MeMo Pad 10 ME102A Motherboard Replacement: adım 13, 2 resimden 1. Asus MeMo Pad 10 ME102A Motherboard Replacement: adım 13, 2 resimden 2.
    • Using the PH00 screwdriver, remove the 4 black M2x4mm screws along the bottom of the motherboard.
  14. Asus MeMo Pad 10 ME102A Motherboard Replacement: adım 14, 1 resimden 1.
    • Using the PH00 screwdriver, remove the 2 silver M2x2mm screws along the top of the motherboard.
  15. Asus MeMo Pad 10 ME102A Motherboard Replacement: adım 15, 1 resimden 1.
    • Lift the motherboard gently from both sides.
Sonuç
5 farklı kişi bu kılavuzu tamamladı.
Andreas Niederer
426 İtibar
2 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 11-3, Blackwell Fall 2016 USF Tampa, Team 11-3, Blackwell Fall 2016 üyesi
USFT-BLACKWELL-F16S11G3
4 Üyeler
10 adet Kılavuz yazıldı
Bir Yorum
super flot hjælp tak tusinde gange
nielsnbc - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 10
Her zaman: 1,887
