Ana içeriğe geç
Asus Memo Pad ME172V - Touch Screen Replacement
Neye ihtiyacın var
Videoya Genel Bakış
  1. Asus Memo Pad ME172V - Touch Screen Replacement, Touch Screen replacement: adım 1, 3 resimden 1. Asus Memo Pad ME172V - Touch Screen Replacement, Touch Screen replacement: adım 1, 3 resimden 2. Asus Memo Pad ME172V - Touch Screen Replacement, Touch Screen replacement: adım 1, 3 resimden 3.
    • Switch-off the tablet.
    • By using a plastic tool open the back / battery cover.
  2. Asus Memo Pad ME172V - Touch Screen Replacement: adım 2, 3 resimden 1. Asus Memo Pad ME172V - Touch Screen Replacement: adım 2, 3 resimden 2. Asus Memo Pad ME172V - Touch Screen Replacement: adım 2, 3 resimden 3.
    • Disconnect and remove the battery.
  3. Asus Memo Pad ME172V - Touch Screen Replacement: adım 3, 3 resimden 1. Asus Memo Pad ME172V - Touch Screen Replacement: adım 3, 3 resimden 2. Asus Memo Pad ME172V - Touch Screen Replacement: adım 3, 3 resimden 3.
    • Disconnect the LCD display flex cable.
    • Disconnect the touchscreen flex cable.
    • Disconnect and remove the loudspeaker.
    • Unscrew 10x screws.
    • Now you can remove the mother board
  4. Asus Memo Pad ME172V - Touch Screen Replacement: adım 4, 3 resimden 1. Asus Memo Pad ME172V - Touch Screen Replacement: adım 4, 3 resimden 2. Asus Memo Pad ME172V - Touch Screen Replacement: adım 4, 3 resimden 3.
    • Remove the metal LCD display shield.
  5. Asus Memo Pad ME172V - Touch Screen Replacement, Separate the LCD panel from the digitizer: adım 5, 3 resimden 1. Asus Memo Pad ME172V - Touch Screen Replacement, Separate the LCD panel from the digitizer: adım 5, 3 resimden 2. Asus Memo Pad ME172V - Touch Screen Replacement, Separate the LCD panel from the digitizer: adım 5, 3 resimden 3.
    • There are many clips holding the LCD panel to the metal frame.
    • Use a spudger to loosen the clips holding the LCD display.
  6. Asus Memo Pad ME172V - Touch Screen Replacement: adım 6, 3 resimden 1. Asus Memo Pad ME172V - Touch Screen Replacement: adım 6, 3 resimden 2. Asus Memo Pad ME172V - Touch Screen Replacement: adım 6, 3 resimden 3.
    • Heat the touch screen.
    • Use a cutter only to start detachment the touchscreen. Then continue with a plastic tool.
  7. Asus Memo Pad ME172V - Touch Screen Replacement: adım 7, 3 resimden 1. Asus Memo Pad ME172V - Touch Screen Replacement: adım 7, 3 resimden 2. Asus Memo Pad ME172V - Touch Screen Replacement: adım 7, 3 resimden 3.
    • After separation the touchscreen from the front bezel, remove the LCD display frame.
    • This spare part have a double sided adhesive tape. Otherwise you should place.
    • Did you do it successfully?
    • Please SUBSCRIBE to my channel ツ
Sonuç
8 farklı kişi bu kılavuzu tamamladı.
ZFix
192.056 İtibar
330 adet Kılavuz yazıldı
Ekip
Master Techs Master Techs üyesi
Community
321 Üyeler
1.525 adet Kılavuz yazıldı
Bir Yorum
Is it possible to replace the bezel the way you would an iPad screen instead of going from the back? I feel like a head gun to the front would save you a lot of hassle? Please correct me if I'm wrong
Alex Tucker - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 4
Her zaman: 23,513
