Ana içeriğe geç
Asus P53E replacement of hard drive or replacement by a SSD Replacement
Neye ihtiyacın var
  1. Asus P53E replacement of hard drive or replacement by a SSD Replacement, replacement of hard drive or replacement by a SSD: adım 1, 1 resimden 1.
    • unscrew these two screws to remove the coverage
  2. Asus P53E replacement of hard drive or replacement by a SSD Replacement: adım 2, 1 resimden 1.
    • unscrew these four screws to take out the case with the hard drive disk
  3. Asus P53E replacement of hard drive or replacement by a SSD Replacement: adım 3, 1 resimden 1.
    • slip the hard drive to the left
  4. Asus P53E replacement of hard drive or replacement by a SSD Replacement: adım 4, 1 resimden 1.
    • pull the strap to remove the hard drive's case
  5. Asus P53E replacement of hard drive or replacement by a SSD Replacement: adım 5, 1 resimden 1.
    • unscrew the four screws of the case to remove the hard drive out of that case
  6. Asus P53E replacement of hard drive or replacement by a SSD Replacement: adım 6, 1 resimden 1.
    • remove the hard drice from its case
  7. Asus P53E replacement of hard drive or replacement by a SSD Replacement: adım 7, 1 resimden 1.
    • put the new hard drive or SSD, respectively in the case and fix the screws again (the HDD/SDD will only fit in the case in one way)
  8. Asus P53E replacement of hard drive or replacement by a SSD Replacement: adım 8, 1 resimden 1.
    • slip the case to the right to plug in the HDD/SDD again
  9. Asus P53E replacement of hard drive or replacement by a SSD Replacement: adım 9, 1 resimden 1.
    • close the case again
Sonuç
Mojo
113 İtibar
1 Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 7
Her zaman: 2,050
