Giriş
This guide will show you how to remove the battery of your Asus PadFone S. Some common tools are required for this replacement so make sure you have them before you start. The battery will be difficult to remove so make sure you follow the directions carefully.
Neye ihtiyacın var
Place your thumb in the charging port and pry the back cover off of the phone.
Remove all screws using the T5 Torx screwdriver
Lift the back panel off the phone.
Bu adımda kullanılan alet:Tweezers$4.99
Disconnect the battery from the logic board using tweezers
Using the plastic opening tools, lift the battery up from its slot
Bir başkası bu kılavuzu tamamladı.
