Ana içeriğe geç
Asus PadFone S Front Facing Camera Replacement
Neye ihtiyacın var
  1. Asus PadFone S Front Facing Camera Replacement, Remove the Back Panel: adım 1, 1 resimden 1.
    • Place your thumb in the charging port and pry the back cover off of the phone.
    FixBot'a Sor
    Yorum Ekle
  2. Asus PadFone S Front Facing Camera Replacement, Remove the Back Panel: adım 2, 2 resimden 1. Asus PadFone S Front Facing Camera Replacement, Remove the Back Panel: adım 2, 2 resimden 2.
    • Remove all screws using the T5 Torx screwdriver
    • Lift the back panel off the phone.
    FixBot'a Sor
    Yorum Ekle
  3. Asus PadFone S Front Facing Camera Replacement, Remove the Battery: adım 3, 2 resimden 1. Asus PadFone S Front Facing Camera Replacement, Remove the Battery: adım 3, 2 resimden 2.
    Bu adımda kullanılan alet:
    • Disconnect the battery from the logic board using tweezers
    • Using the plastic opening tools, lift the battery up from its slot
    • Apply consistent, steady force to lift the battery from its slot. Be careful not to damage the battery while removing it.
    FixBot'a Sor
    Yorum Ekle
  4. Asus PadFone S Front Facing Camera Replacement, Front Facing Camera: adım 4, 3 resimden 1. Asus PadFone S Front Facing Camera Replacement, Front Facing Camera: adım 4, 3 resimden 2. Asus PadFone S Front Facing Camera Replacement, Front Facing Camera: adım 4, 3 resimden 3.
    • Once the Battery has been successfully removed, move on to the step 2.
    FixBot'a Sor
    Yorum Ekle
  5. Asus PadFone S Front Facing Camera Replacement, Start of Logic Board Removal: adım 5, 2 resimden 1. Asus PadFone S Front Facing Camera Replacement, Start of Logic Board Removal: adım 5, 2 resimden 2.
    • Disconnect the marked strips from the logic board using the tweezers.
    • Applying too much force may damage the strips/connectors.
    • Remember to remove speaker connection located at the bottom left hand corner.
    FixBot'a Sor
    Yorum Ekle
  6. Asus PadFone S Front Facing Camera Replacement, Logic Board Removal - Continued: adım 6, 2 resimden 1. Asus PadFone S Front Facing Camera Replacement, Logic Board Removal - Continued: adım 6, 2 resimden 2.
    • Disconnect the other two strips that connect the logic board to the phone.
    FixBot'a Sor
    Yorum Ekle
  7. Asus PadFone S Front Facing Camera Replacement, Remove The Camera: adım 7, 2 resimden 1. Asus PadFone S Front Facing Camera Replacement, Remove The Camera: adım 7, 2 resimden 2.
    • Turn over the logic board to locate the front camera.
    • Grasp the sides of the camera with the tweezers and carefully remove the camera from the logic board.
    • Applying to much force will damage the connective strip.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Ekip
UMass Dartmouth, Team 6-1, Vijaybhaskar Fall 2014 UMass Dartmouth, Team 6-1, Vijaybhaskar Fall 2014 üyesi
UMASSD-VIJAYBHASKAR-F14S6G1
3 Üyeler
15 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 6
Son 30 gün: 25
Her zaman: 1,817
