Ana içeriğe geç
Asus PadFone S Motherboard Replacement
Neye ihtiyacın var
  1. Asus PadFone S Motherboard Replacement, Remove the Back Panel: adım 1, 1 resimden 1.
    • Place your thumb in the charging port and pry the back cover off of the phone.
  2. Asus PadFone S Motherboard Replacement, Remove the Back Panel: adım 2, 2 resimden 1. Asus PadFone S Motherboard Replacement, Remove the Back Panel: adım 2, 2 resimden 2.
    • Remove all screws using the T5 Torx screwdriver
    • Lift the back panel off the phone.
  3. Asus PadFone S Motherboard Replacement, Remove the Battery: adım 3, 2 resimden 1. Asus PadFone S Motherboard Replacement, Remove the Battery: adım 3, 2 resimden 2.
    • Disconnect the battery from the logic board using tweezers
    • Using the plastic opening tools, lift the battery up from its slot
    • Apply consistent, steady force to lift the battery from its slot. Be careful not to damage the battery while removing it.
  4. Asus PadFone S Motherboard Replacement, Disconnect the Logic Board: adım 4, 3 resimden 1. Asus PadFone S Motherboard Replacement, Disconnect the Logic Board: adım 4, 3 resimden 2. Asus PadFone S Motherboard Replacement, Disconnect the Logic Board: adım 4, 3 resimden 3.
    • Disconnect all wires and bands from microphone, SIM card port and side bottons
  5. Asus PadFone S Motherboard Replacement, Remove the Logic Board: adım 5, 3 resimden 1. Asus PadFone S Motherboard Replacement, Remove the Logic Board: adım 5, 3 resimden 2. Asus PadFone S Motherboard Replacement, Remove the Logic Board: adım 5, 3 resimden 3.
    • Disconnect remaining band from the logic board
    • Lift the logic board out of the phone
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Greg Betsold
96 İtibar
3 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 6-1, Vijaybhaskar Fall 2014 UMass Dartmouth, Team 6-1, Vijaybhaskar Fall 2014 üyesi
UMASSD-VIJAYBHASKAR-F14S6G1
3 Üyeler
10 adet Kılavuz yazıldı
Bir Yorum
need schematic side button asus padfone s..please send via email kepkep.erwin@gmail.com.
thanks..
kepkep - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 12
Son 30 gün: 18
Her zaman: 3,589
