Ana içeriğe geç
Asus PadFone S Rear Facing Camera Replacement
Neye ihtiyacın var
  1. Asus PadFone S Rear Facing Camera Replacement, Remove Back Cover: adım 1, 2 resimden 1. Asus PadFone S Rear Facing Camera Replacement, Remove Back Cover: adım 1, 2 resimden 2.
    • Place your thumb in the charging port and pry the back cover off of the phone.
    • Separate cover all the way around the sides of the phone.
  2. Asus PadFone S Rear Facing Camera Replacement, Remove Back Panel: adım 2, 2 resimden 1. Asus PadFone S Rear Facing Camera Replacement, Remove Back Panel: adım 2, 2 resimden 2.
    • Remove all the screws on the back panel using a T5 Torx screwdriver.
    • Lift the back panel off to reveal the logic board and battery.
  3. Asus PadFone S Rear Facing Camera Replacement, Remove Back Camera: adım 3, 3 resimden 1. Asus PadFone S Rear Facing Camera Replacement, Remove Back Camera: adım 3, 3 resimden 2. Asus PadFone S Rear Facing Camera Replacement, Remove Back Camera: adım 3, 3 resimden 3.
    • The back camera is located at the top left on the logic board.
    • Use tweezers to lift back camera strip from logic board.
    • Lift back camera out of logic board.
    • It is not necessary to remove logic board for removal of the back camera.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Christian Trippe
79 İtibar
1 Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 6-1, Vijaybhaskar Fall 2014 UMass Dartmouth, Team 6-1, Vijaybhaskar Fall 2014 üyesi
UMASSD-VIJAYBHASKAR-F14S6G1
3 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 1
Her zaman: 1,339
