Giriş
This guide will show you how to remove the side buttons of your Asus PadFone S. Some common tools are required for this replacement so make sure you have them before you start. This guide will make it easy to replace a broken side buttons to get your phone working again.
  1. Place your thumb in the charging port and pry off the back cover.
    • Place your thumb in the charging port and pry off the back cover.
  2. Pro Tech Toolkit içeren veya $100tüm siparişlerde ücretsiz kargo!
    Mağazamıza Göz Atın
  3. Remove all screws using a T5 Torx screwdriver. After removing screws, lift the back panel off of the phone.
    • Remove all screws using a T5 Torx screwdriver.
    • After removing screws, lift the back panel off of the phone.
  4. Turn the phone so the left edge is facing you.
    • Turn the phone so the left edge is facing you.
    • Using your fingers, gently pull up on the buttons to remove them from the phone.
Sonuç
Greg Betsold
96 İtibar
3 adet Kılavuz yazıldı
Takım
UMass Dartmouth, Team 6-1, Vijaybhaskar Fall 2014 UMass Dartmouth, Team 6-1, Vijaybhaskar Fall 2014 üyesi
UMASSD-VIJAYBHASKAR-F14S6G1
3 Üyeler
5 adet Kılavuz yazıldı
Bir Yorum
My Asus Padfone S Side
Buttons Got Error ..
Its Press It But No Peanuts ( Klik Sound ) Inside :(
How To Fix It ??
By Ndra - Yanıt
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 Gün: 1
Son 30 Gün: 2
Her zaman: 861
