Ana içeriğe geç
Asus PadFone S Side Buttons Replacement
Neye ihtiyacın var
  1. Asus PadFone S Side Buttons Replacement, Remove Back Cover: adım 1, 1 resimden 1.
    • Place your thumb in the charging port and pry off the back cover.
  2. Asus PadFone S Side Buttons Replacement, Remove Back Panel: adım 2, 2 resimden 1. Asus PadFone S Side Buttons Replacement, Remove Back Panel: adım 2, 2 resimden 2.
    • Remove all screws using a T5 Torx screwdriver.
    • After removing screws, lift the back panel off of the phone.
  3. Asus PadFone S Side Buttons Replacement, Remove Side Buttons: adım 3, 1 resimden 1.
    • Turn the phone so the left edge is facing you.
    • Using your fingers, gently pull up on the buttons to remove them from the phone.
Sonuç
Greg Betsold
96 İtibar
3 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 6-1, Vijaybhaskar Fall 2014 UMass Dartmouth, Team 6-1, Vijaybhaskar Fall 2014 üyesi
UMASSD-VIJAYBHASKAR-F14S6G1
3 Üyeler
10 adet Kılavuz yazıldı
Bir Yorum
My Asus Padfone S Side
Buttons Got Error ..
Its Press It But No Peanuts ( Klik Sound ) Inside :(
How To Fix It ??
By Ndra - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 7
Her zaman: 1,049
