Ana içeriğe geç
Asus Padfone 2 A68 Sub Cables Replacement
Neye ihtiyacın var
    1. Asus Padfone 2 A68 Sub Cables Replacement, Power Down Device: adım 1, 1 resimden 1.
      • Hold down the power button.
      FixBot'a Sor
      Yorum Ekle
    2. Asus Padfone 2 A68 Sub Cables Replacement, Remove Back Plate: adım 2, 3 resimden 1. Asus Padfone 2 A68 Sub Cables Replacement, Remove Back Plate: adım 2, 3 resimden 2. Asus Padfone 2 A68 Sub Cables Replacement, Remove Back Plate: adım 2, 3 resimden 3.
      • Use plastic opening tools to pry off the cover of the phone.
      FixBot'a Sor
      Yorum Ekle
    3. Asus Padfone 2 A68 Sub Cables Replacement, Battery Removal: adım 3, 3 resimden 1. Asus Padfone 2 A68 Sub Cables Replacement, Battery Removal: adım 3, 3 resimden 2. Asus Padfone 2 A68 Sub Cables Replacement, Battery Removal: adım 3, 3 resimden 3.
      Bu adımda kullanılan alet:
      • Remove the warning sticker that covers the battery plug and connecting cord.
      • Look for the widest gap on either side of the battery. Using the plastic opening tool carefully lift battery out.
      • The battery is held down with adhesive. Be careful not to damage battery or connecting cord.
      • Disconnect battery connecting cord using tweezers.
      FixBot'a Sor
      Yorum Ekle
    4. Asus Padfone 2 A68 Sub Cables Replacement, Remove Internal Back Plate: adım 4, 2 resimden 1. Asus Padfone 2 A68 Sub Cables Replacement, Remove Internal Back Plate: adım 4, 2 resimden 2.
      • Use a T5 Torx screwdriver to remove 14 screws from internal back plate.
      • Use of magnetic pad will help with keeping track of screws.
      • Once screws are out, remove the plate.
      FixBot'a Sor
      Yorum Ekle
    5. Asus Padfone 2 A68 Sub Cables Replacement, Removal of A68 Sub Cables: adım 5, 1 resimden 1.
      • Use tweezers to unplug the sub cables from the circuit board and housing.
      FixBot'a Sor
      Yorum Ekle
    6. Asus Padfone 2 A68 Sub Cables Replacement, Replacing the A68 Sub Cables: adım 6, 2 resimden 1. Asus Padfone 2 A68 Sub Cables Replacement, Replacing the A68 Sub Cables: adım 6, 2 resimden 2.
      • Plug in new sub cables to the circuit board and housing.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Erica
482 İtibar
2 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 5-4, Mcgee Fall 2014 USF Tampa, Team 5-4, Mcgee Fall 2014 üyesi
USFT-MCGEE-F14S5G4
4 Üyeler
47 adet Kılavuz yazıldı
1Rehber Yorum
Boas. Onde posso comprar este cabo?
rsebastiao - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 22
Her zaman: 1,582
