Ana içeriğe geç
Asus Padfone 2 Battery Replacement
Neye ihtiyacın var
    1. Asus Padfone 2 Battery Replacement, Power off phone: adım 1, 1 resimden 1.
      • Hold down power button to shut off phone.
      FixBot'a Sor
      Yorum Ekle
    2. Asus Padfone 2 Battery Replacement, Remove back cover of phone: adım 2, 2 resimden 1. Asus Padfone 2 Battery Replacement, Remove back cover of phone: adım 2, 2 resimden 2.
      • Use plastic opening tool to pry off the back cover of the phone.
      FixBot'a Sor
      Yorum Ekle
    3. Asus Padfone 2 Battery Replacement, Battery Removal: adım 3, 3 resimden 1. Asus Padfone 2 Battery Replacement, Battery Removal: adım 3, 3 resimden 2. Asus Padfone 2 Battery Replacement, Battery Removal: adım 3, 3 resimden 3.
      Bu adımda kullanılan alet:
      • Remove the warning sticker that covers the battery plug and connecting cord.
      • Look for the widest gap on either side of the battery. Using the plastic opening tool carefully lift battery out.
      • The battery is held down with adhesive. Be careful not to damage battery or connecting cord
      • Disconnect battery connecting cord using tweezers.
      FixBot'a Sor
      Yorum Ekle
Sonuç
7 farklı kişi bu kılavuzu tamamladı.
Zach Standridge
368 İtibar
2 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 5-4, Mcgee Fall 2014 USF Tampa, Team 5-4, Mcgee Fall 2014 üyesi
USFT-MCGEE-F14S5G4
4 Üyeler
35 adet Kılavuz yazıldı
1Rehber Yorum
Pull the battery connector towards USB. You will break it if you pull it up, as I did.
I wouldn’t recommend metal tweezers as it could shortcut the battery.
Los Karlos - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 32
Her zaman: 6,422
