Ana içeriğe geç
Asus Padfone 2 Camera Replacement
Neye ihtiyacın var
    1. Asus Padfone 2 Camera  Replacement, Power Down Device: adım 1, 1 resimden 1.
      • Hold down the power button.
      FixBot'a Sor
      Yorum Ekle
    2. Asus Padfone 2 Camera  Replacement, Remove Back Plate: adım 2, 3 resimden 1. Asus Padfone 2 Camera  Replacement, Remove Back Plate: adım 2, 3 resimden 2. Asus Padfone 2 Camera  Replacement, Remove Back Plate: adım 2, 3 resimden 3.
      • Use plastic opening tool to pry off the back cover of the phone.
      FixBot'a Sor
      Yorum Ekle
    3. Asus Padfone 2 Camera  Replacement, Battery Removal: adım 3, 3 resimden 1. Asus Padfone 2 Camera  Replacement, Battery Removal: adım 3, 3 resimden 2. Asus Padfone 2 Camera  Replacement, Battery Removal: adım 3, 3 resimden 3.
      Bu adımda kullanılan alet:
      • Remove the warning sticker that covers the battery plug and connecting cord.
      • Look for the widest gap on either side of the battery. Using the plastic opening tool carefully lift battery out.
      • The battery is held down with adhesive. Be careful not to damage battery or connecting cord.
      • Disconnect battery connecting cord using tweezers.
      FixBot'a Sor
      Yorum Ekle
    4. Asus Padfone 2 Camera  Replacement, Remove Internal Back Plate: adım 4, 3 resimden 1. Asus Padfone 2 Camera  Replacement, Remove Internal Back Plate: adım 4, 3 resimden 2. Asus Padfone 2 Camera  Replacement, Remove Internal Back Plate: adım 4, 3 resimden 3.
      • Use T5 Torx screwdriver to remove 14 screws from internal back plate.
      • Use of magnetic pad will help with keeping track of screws.
      • Once screws are out, remove the plate.
      FixBot'a Sor
      Yorum Ekle
    5. Asus Padfone 2 Camera  Replacement, Disconnect Motherboard: adım 5, 3 resimden 1. Asus Padfone 2 Camera  Replacement, Disconnect Motherboard: adım 5, 3 resimden 2. Asus Padfone 2 Camera  Replacement, Disconnect Motherboard: adım 5, 3 resimden 3.
      • Disconnect four plugs to the motherboard using tweezers.
      • Lift up green motherboard.
      FixBot'a Sor
      Yorum Ekle
    6. Asus Padfone 2 Camera  Replacement, Removing Camera: adım 6, 2 resimden 1. Asus Padfone 2 Camera  Replacement, Removing Camera: adım 6, 2 resimden 2.
      • Remove camera from back of the motherboard with tweezers.
      FixBot'a Sor
      Yorum Ekle
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Erica
482 İtibar
2 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 5-4, Mcgee Fall 2014 USF Tampa, Team 5-4, Mcgee Fall 2014 üyesi
USFT-MCGEE-F14S5G4
4 Üyeler
35 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 24
Her zaman: 2,305
