Ana içeriğe geç
Asus Padfone 2 Vibrator Replacement
Neye ihtiyacın var
  1. Asus Padfone 2 Vibrator Replacement, Power Down Device: adım 1, 1 resimden 1.
    • Hold down the power button
    FixBot'a Sor
    Yorum Ekle
  2. Asus Padfone 2 Vibrator Replacement, Remove Back Plate: adım 2, 3 resimden 1. Asus Padfone 2 Vibrator Replacement, Remove Back Plate: adım 2, 3 resimden 2. Asus Padfone 2 Vibrator Replacement, Remove Back Plate: adım 2, 3 resimden 3.
    • Use plastic opening tool to pry off the back cover of the phone.
    FixBot'a Sor
    Yorum Ekle
  3. Asus Padfone 2 Vibrator Replacement, Battery Removal: adım 3, 3 resimden 1. Asus Padfone 2 Vibrator Replacement, Battery Removal: adım 3, 3 resimden 2. Asus Padfone 2 Vibrator Replacement, Battery Removal: adım 3, 3 resimden 3.
    Bu adımda kullanılan alet:
    • Remove the warning sticker that covers the battery plug and connecting cord.
    • Look for the widest gap on either side of the battery. Using the plastic opening tool carefully lift battery out.
    • The battery is held down with adhesive. Be careful not to damage battery or connecting cord.
    • Disconnect battery connecting cord using tweezers.
    FixBot'a Sor
    Yorum Ekle
  4. Asus Padfone 2 Vibrator Replacement, Remove Internal Back Plate: adım 4, 2 resimden 1. Asus Padfone 2 Vibrator Replacement, Remove Internal Back Plate: adım 4, 2 resimden 2.
    • Use T5 Torx screwdriver to remove 14 screws from internal back plate.
    • Use of magnetic pad will help with keeping track of screws.
    • Once screws are out, remove the plate.
    FixBot'a Sor
    Yorum Ekle
  5. Asus Padfone 2 Vibrator Replacement, Removal of A68 Vibrator: adım 5, 2 resimden 1. Asus Padfone 2 Vibrator Replacement, Removal of A68 Vibrator: adım 5, 2 resimden 2.
    • Use tweezers to remove motor from housing, pulling the plug downward away from the phone.
    • Use tweezers to unplug the device from the circuit board.
    FixBot'a Sor
    Yorum Ekle
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Zach Standridge
368 İtibar
2 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 5-4, Mcgee Fall 2014 USF Tampa, Team 5-4, Mcgee Fall 2014 üyesi
USFT-MCGEE-F14S5G4
4 Üyeler
11 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 28
Her zaman: 1,725
