Neye ihtiyacın var
Bu adımda kullanılan alet:Tweezers$4.99
Remove the warning sticker that covers the battery plug and connecting cord.
Look for the widest gap on either side of the battery. Using the plastic opening tool carefully lift battery out.
Disconnect battery connecting cord using tweezers.
Use T5 Torx screwdriver to remove 14 screws from internal back plate.
Once screws are out, remove the plate.
Use tweezers to remove motor from housing, pulling the plug downward away from the phone.
Use tweezers to unplug the device from the circuit board.
2 farklı kişi bu kılavuzu tamamladı.
