Ana içeriğe geç
Asus Padfone X Mini Screen Replacement
Neye ihtiyacın var
    1. Asus Padfone X Mini Screen Replacement, Speaker: adım 1, 1 resimden 1.
      • With the phone facing down, look at the bottom right side corner and there should be a groove. Use a plastic opening tool and lift up to remove outside cover.
      • This is not the cover with the speaker attached.
      FixBot'a Sor
      Yorum Ekle
    2. Asus Padfone X Mini Screen Replacement: adım 2, 1 resimden 1.
      • Lift the battery out from the top of the device.
      FixBot'a Sor
      Yorum Ekle
    3. Asus Padfone X Mini Screen Replacement: adım 3, 1 resimden 1.
      • Around the perimeter, there should be 10 2 mm T5 Torx screws. Take them out.
      • Remove the cover.
      FixBot'a Sor
      Yorum Ekle
    4. Asus Padfone X Mini Screen Replacement: adım 4, 1 resimden 1.
      • Turn the cover over.
      • The speaker is attached to the inside of the cover and to the right of the camera hole.
      FixBot'a Sor
      Yorum Ekle
    5. Asus Padfone X Mini Screen Replacement: adım 5, 1 resimden 1.
      Bu adımda kullanılan alet:
      • Remove speaker with standard tweezers to minimize damage, and replace.
      FixBot'a Sor
      Yorum Ekle
    1. Asus Padfone X Mini Screen Replacement, Screen: adım 6, 1 resimden 1.
      • Detach the black connector on the left hand side of the motherboard.
      • Don't completely remove the black connector.
      FixBot'a Sor
      Yorum Ekle
    2. Asus Padfone X Mini Screen Replacement: adım 7, 1 resimden 1.
      • Disconnect silver connector from the motherboard. It is located on the left hand side above the black connector.
      FixBot'a Sor
      Yorum Ekle
    3. Asus Padfone X Mini Screen Replacement: adım 8, 2 resimden 1. Asus Padfone X Mini Screen Replacement: adım 8, 2 resimden 2.
      • Remove motherboard and replace screen.
      FixBot'a Sor
      Yorum Ekle
Sonuç
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 8
Son 30 gün: 27
Her zaman: 584
