Ana içeriğe geç
Asus Q200E-CT144H Screen Replacement
Neye ihtiyacın var
    1. Asus Q200E-CT144H Screen Replacement, Screen: adım 1, 1 resimden 1.
      • Turn off the laptop and disconnect the power cable.
      • If the laptop is powered on, it could cause an electric shock.
      • Open the laptop and place it on a hard, flat surface with the screen facing up.
      FixBot'a Sor
      Yorum Ekle
    2. Asus Q200E-CT144H Screen Replacement: adım 2, 2 resimden 1. Asus Q200E-CT144H Screen Replacement: adım 2, 2 resimden 2.
      • Take a metal spudger and insert it under the screen.
      • Slowly move the spudger across the length of the screen, separating the sections.
      FixBot'a Sor
      Yorum Ekle
    3. Asus Q200E-CT144H Screen Replacement: adım 3, 1 resimden 1.
      • Remove the four 3.3mm Phillips #00 screws.
      FixBot'a Sor
      Yorum Ekle
    4. Asus Q200E-CT144H Screen Replacement: adım 4, 1 resimden 1.
      Bu adımda kullanılan alet:
      • Pull apart the screen from the casing of the laptop.
      • Disconnect the power connector using tweezers.
      FixBot'a Sor
      Yorum Ekle
Sonuç
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 22
Her zaman: 645
