Ana içeriğe geç
Asus Q200E-CT144H Screen Replacement
Neye ihtiyacın var
  1. Asus Q200E-CT144H Screen Replacement, Screen: adım 1, 1 resimden 1.
    • Turn off the laptop and disconnect the power cable.
    • If the laptop is powered on, it could cause an electric shock.
    • Open the laptop and place it on a hard, flat surface with the screen facing up.
  2. Asus Q200E-CT144H Screen Replacement: adım 2, 2 resimden 1. Asus Q200E-CT144H Screen Replacement: adım 2, 2 resimden 2.
    • Take a metal spudger and insert it under the screen.
    • Slowly move the spudger across the length of the screen, separating the sections.
  3. Asus Q200E-CT144H Screen Replacement: adım 3, 1 resimden 1.
    • Remove the four 3.3mm Phillips #00 screws.
  4. Asus Q200E-CT144H Screen Replacement: adım 4, 1 resimden 1.
    • Pull apart the screen from the casing of the laptop.
    • Disconnect the power connector using tweezers.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 7
Her zaman: 261
