Ana içeriğe geç
Asus Q200E-CT144H Speaker Replacement
Neye ihtiyacın var
  1. Asus Q200E-CT144H Speaker Replacement, Back Cover: adım 1, 1 resimden 1.
    • To start, turn off the laptop and disconnect the power cable.
    • If the computer is on or plugged in, it could cause electric shock.
    • Flip the laptop over so the back panel is visible.
  2. Asus Q200E-CT144H Speaker Replacement: adım 2, 1 resimden 1.
    • Remove the 9 screws holding the cover in place by taking a Phillips #00 Screwdriver and turning it counterclockwise.
  3. Asus Q200E-CT144H Speaker Replacement: adım 3, 2 resimden 1. Asus Q200E-CT144H Speaker Replacement: adım 3, 2 resimden 2.
    • Use an iFixit opening tool to lift the back cover and remove it from the laptop.
  4. Asus Q200E-CT144H Speaker Replacement, Battery: adım 4, 2 resimden 1. Asus Q200E-CT144H Speaker Replacement, Battery: adım 4, 2 resimden 2.
    Bu adımda kullanılan alet:
    Satın Al
    • Remove the battery connector by using tweezers to lift up on it.
  5. Asus Q200E-CT144H Speaker Replacement: adım 5, 2 resimden 1. Asus Q200E-CT144H Speaker Replacement: adım 5, 2 resimden 2.
    • Remove the nine Phillips #00 screws that hold the battery in place.
    • There is one 9.2mm screw, four 4.7mm screws, and four 5.7mm screws.
  6. Asus Q200E-CT144H Speaker Replacement: adım 6, 2 resimden 1. Asus Q200E-CT144H Speaker Replacement: adım 6, 2 resimden 2.
    • Remove the battery from the battery bay.
  7. Asus Q200E-CT144H Speaker Replacement, Speaker: adım 7, 1 resimden 1.
    Satın Al
    • Use tweezers to disconnect the speaker's main power connectors.
  8. Asus Q200E-CT144H Speaker Replacement: adım 8, 2 resimden 1. Asus Q200E-CT144H Speaker Replacement: adım 8, 2 resimden 2.
    • Use a metal spudger to pry the speaker housing from the laptop.
    • There will be glue holding the speaker housing to the laptop.
  9. Asus Q200E-CT144H Speaker Replacement: adım 9, 2 resimden 1. Asus Q200E-CT144H Speaker Replacement: adım 9, 2 resimden 2.
    • Remove the right speaker from its housing.
    • Use tweezers to remove the black and white wire from its groove.
    • The black and white wire connects the speaker housings together.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 5
Her zaman: 122
