Giriş
If you notice that your laptop’s audio transmission is distorted or there isn’t any sound coming from the computer altogether, there may be a problem with the speaker. Maybe you’ve tried everything in your power to troubleshoot the speakers and reached a dead end. In this case you can use this repair guide to help you replace the speakers in the laptop.
Neye ihtiyacın var
To start, turn off the laptop and disconnect the power cable.
Flip the laptop over so the back panel is visible.
Remove the battery connector by using tweezers to lift up on it.
Use tweezers to disconnect the speaker's main power connectors.
