Ana içeriğe geç
Asus Q302UA-BHI5T20 Fan and Heat Sink Replacement
Neye ihtiyacın var
  1. Asus Q302UA-BHI5T20 Fan and Heat Sink Replacement, Fan and Heat Sink: adım 1, 2 resimden 1. Asus Q302UA-BHI5T20 Fan and Heat Sink Replacement, Fan and Heat Sink: adım 1, 2 resimden 2.
    • Unscrew the ten 10mm Phillips #0 screws.
    • Use the plastic opening tool along the side of the laptop to pry open.
  2. Asus Q302UA-BHI5T20 Fan and Heat Sink Replacement: adım 2, 2 resimden 1. Asus Q302UA-BHI5T20 Fan and Heat Sink Replacement: adım 2, 2 resimden 2.
    • Remove the seven 4mm Phillips #0 screws.
    • Gently pull the connector.
  3. Asus Q302UA-BHI5T20 Fan and Heat Sink Replacement: adım 3, 1 resimden 1.
    • Lift the heat sink and fan assembly, and you are done!
    • There maybe a little resistance to being pulled up since the heat sink is attached to the CPU with thermal paste
Sonuç
Bir başkası bu kılavuzu tamamladı.
Arthur Sperotto
118 İtibar
1 Kılavuz yazıldı
Ekip
IUPUI, Team S1-G2, Hovde Fall 2018 IUPUI, Team S1-G2, Hovde Fall 2018 üyesi
IUPUI-HOVDE-F18S1G2
3 Üyeler
3 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 13
Her zaman: 133
