Ana içeriğe geç
Asus Q302UA-BHI5T20 Hard Drive Replacement
Neye ihtiyacın var
  1. Asus Q302UA-BHI5T20 Hard Drive Replacement, Hard Drive: adım 1, 1 resimden 1.
    • Remove the ten 10mm Phillips #0 screws.
  2. Asus Q302UA-BHI5T20 Hard Drive Replacement: adım 2, 1 resimden 1.
    • Use the iFixit opening tool to pry off the back cover of the laptop.
  3. Asus Q302UA-BHI5T20 Hard Drive Replacement: adım 3, 2 resimden 1. Asus Q302UA-BHI5T20 Hard Drive Replacement: adım 3, 2 resimden 2.
    • Remove the four screws from the hard drive bracket.
    • Remove the five 4 mm Phillips screws.
  4. Asus Q302UA-BHI5T20 Hard Drive Replacement: adım 4, 2 resimden 1. Asus Q302UA-BHI5T20 Hard Drive Replacement: adım 4, 2 resimden 2.
    • Pull on this black connector piece to remove it from the hard drive.
    • The second picture shows how things should look at this point.
  5. Asus Q302UA-BHI5T20 Hard Drive Replacement: adım 5, 1 resimden 1.
    • Remove these two 4 mm Phillips screws holding the hard drive to the bracket. Repeat on the other side of the bracket.
    • Pull the HD from its housing.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Houston Koontz
319 İtibar
2 adet Kılavuz yazıldı
Ekip
IUPUI, Team S1-G2, Hovde Fall 2018 IUPUI, Team S1-G2, Hovde Fall 2018 üyesi
IUPUI-HOVDE-F18S1G2
3 Üyeler
3 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 10
Her zaman: 376
